LS4 Performance - Rear Brakes
bigboymike68
04-06-2012, 05:03 PM
I have noticed that the rear brakes on my 06 Impala SS are not working right. While I changed the struts on it I held the brakes and you can still turn the rear wheels. When I drive easy they seem to work but under heavy braking I get real bad nose down tail up action. The brakes are new front and rear. The calibers front and rear are new as well.
Barnett92
04-06-2012, 05:26 PM
You may have knicked or bent a brake line to your rear. Did you see any fluid spilled? Check your resovior? I hope you find your problem!
bigboymike68
04-06-2012, 05:44 PM
nope. no spills, no leaks, dry as a bone. reservoir full.
Barnett92
04-06-2012, 06:07 PM
Thats strange. The only thing I could think of is a bent line or air got into your lines somehow.
badata
04-06-2012, 09:46 PM
Just asking but why did you change all four calipers? I would try and bleed the system. Double check make sure all bleeder screws are at the top, maybe they were switched or put upside down? How does pedal feel? Could even be a bad master cylinder. Is it both rear wheels?
Panther427
04-06-2012, 11:01 PM
Um did you remove the plug out of the feed line to the calipers when you installed
bigboymike68
04-07-2012, 01:55 PM
They were all done from the dealership that I got it from.
Barnett92
04-07-2012, 04:13 PM
I would defiantly take your car back to that same dealer then. Whatever they did, its all THEIR fault and nothing you did ;)
Panther427
04-07-2012, 04:44 PM
Ya generally dealers have a 12 months, 12,000 mile warranty on there work they preform
bigboymike68
04-07-2012, 05:00 PM
It wasn't warranty work. Plus the warranty is already done on the car
Panther427
04-07-2012, 09:19 PM
Doesn't matter. They back any work preformed on any car. Doesn't have to be "under" warranty.
gxp-miller-gxp
04-07-2012, 11:56 PM
your car could be 60 years past warranty, if u take it in for example a window not staying up and they repair it and it falls back down a week later they are responsible and u take it back and have it repaired for free
if the pedal isnt spongy, then it sounds like the caliper's piston is hung up. It happens and even new calipers can be defective. The first generation W-bodies had defective rear brakes, I was replacing my rear brakes every 10 months and twice I received bad calipers where someone could be stepping on the brake pedal and I could still turn the wheel by hand.
Also, however I'm not 100% sure... you could might be able to have a firm brake pedal however the ABS pump might need to be bled as well.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
