Fueling & Injection - Need to drain 1994 z28 gas tank...
rossledford
04-06-2012, 10:05 PM
How do i drain the fuel tank without dropping the rearend? or how do i trick the fuel pump into draining the fuel tank?
F0x Slaughter
04-06-2012, 11:39 PM
By the PCM there is a connector that isn't hooked up to anything. Its for making the fuel pump kick on to drain the tank.
rossledford
04-07-2012, 07:13 AM
ok dumb question then, where is the pcm located and what do i connect to the connector to make it dump the fuel? please help
01ssreda4
04-14-2012, 04:15 AM
Hole in the bottom of the tank, works really well. A sawzall can do the job. Seen it done once. 10 gallons gone in about 60 secs.
F0x Slaughter
04-14-2012, 09:37 AM
If you pop the hood, while looking at the engine its in the upper passenger side. Its a black box with all the harnesses running to it. You will look around and see a connector that isn't hooked up. It will allow you to power the fuel pump.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
