jmargo
04-06-2012, 10:37 PM
Need to pull the rear bumper on the V1 to get a spot repainted. I see nuts inside the trunk and plastic tabs in the wheel wells and bottom by the spare tire well. Are there any tricks to get it off ?
Thanks
1BADCTS
04-06-2012, 10:51 PM
No tricks that I remember. Just start removing the nuts and gently tugging to make sure you got all of them. I remember some of them in the wheel area being a PITA to get too when re-installing it.
blkgagt94
04-26-2012, 07:39 PM
Two 7mm on each side two push clips on each side take both tail lights out 3 push clips under middle an 5 10mm on each side best to be under car for sides
