New LS1 Owners - Newbie Tech - Windage tray??
Rmccomb
04-07-2012, 12:56 AM
Quick question..
I have an Fbody ls1 with the factory windage tray, and I just ordered a front sump gto pan for my swap, I was wondering if A) can I use the stock f body windage tray, or do I have to get a gto tray? And B) do I "need" a windage tray imparitively if I can't use the f body tray?
Thanks for the advice in advance
Rmccomb
04-07-2012, 03:14 PM
No body?
Rmccomb
04-08-2012, 08:41 PM
still trying to find this out... oil pan will be here in like 3 days
Nissan LS240
04-10-2012, 09:21 AM
use the windage tray, keeps oil from sloshing around with the crank, I had to put a front sump oil pan but I got mine from sikky as a kit and the pick up tube was made for the swap, you run into a problem trying to use the stock pick up tube in the gto pan, and then you run into a problem if you try to use gto pick up with ls1 windage tray, but you could just drill a hole in the windage tray to clear gto pick up tube
Rmccomb
04-10-2012, 11:51 AM
ok, cool, thats exactly what i needed to know!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
