Maxiumum agreeable boost with a blown LS2
Old 04-07-2012, 06:49 AM
hotparts's Avatar
Exclamation Maxiumum agreeable boost with a blown LS2
Hi guys,
i have a blown LS2 Vortech V7, callies crank kit, forged pistons,...
Till now i had about 21 psi without problems.
Now i want to change to the new procharger F1X but i feel angry that the boost (about 26 psi) is too much for this motor block?
What is the maxiumum agreeable boost with a blown LS2?
I heared that one guy cracked the cylinder sleeve with this blower.
What do you think?
Thank you
Old 04-07-2012, 06:53 AM
Mr.Big's Avatar
LS2 Block at 29psi here... remember boost is a measure of restriction so comparing boost numbers to a different setup is pointless...
Old 04-07-2012, 07:19 AM
hotparts's Avatar
Do you use the stock cylinder sleeves?
Old 04-07-2012, 12:35 PM
HRHohio's Avatar
Compression Ratio?
Heads? (Ported?)
Intake?
Old 04-07-2012, 04:41 PM
BigRich954RR's Avatar
put the f1x on you can set the psi any where u want but you should make more power at the same psi with the f1x
Quick Reply: Maxiumum agreeable boost with a blown LS2
