D1 procharged ls2 800 hp 80lb injectors, which fuel pump should I go with?
I have a d1 procharger ls2 with 80 lb injectors, Im wanting to know which fuel pump i should go with? I was going with with a aeromotive 1000 but people have been iffy about them. So i was thinking a magnafuel, but which one should i go with? Quickstar 300?
call Lonnie. he will have you setup in no time, great price, great quality, and noone on here will disagree with me there. personally I am going with dual in tanks.
http://www.lonniesperformance.com/
One more vote for a Lonnie double pumper. Read my first post in this thread it tells the tale of my fuel pressure problems. https://ls1tech.com/forums/fueling-i...ual-pumps.html
Also Lonnie can set you up with the right size fuel lines and pressure regulator you'll need for your hp goal. Stockers aren't going to cut it.
A guy told me one bad thing about dual pumps on a forum.. if one pump goes bad then it can still run but then go lean and burn up the engine... If one pump goes out then you know . but i guess if your paying attention to the gauges you should notice either way lol
