Gears & Axles - Moser 12 bolt leaking have some questions.
95LTXZ28
04-07-2012, 12:58 PM
Hey guys yesterday I installed the new Gmmg on my car and noticed there is like a coating of oil all over the rear cover. I dont know if it's because the rear is overfilled or a plug or the rear gasket is leaking. Just wondering if you guys have any insight to narrow down the leaky spot. It's not leaving a puddle, the housing and rear cover are just coated.
mozmale
04-08-2012, 06:13 PM
If its fresh then you should probably get a gasket and replace the rtv you likely have in the gaskets place, but if the oil is old and caked I wouldn't worry about it, no puddles? Good, now just see if it's fresh leakage.
01ssreda4
04-08-2012, 06:40 PM
Best thing is to pinpoint the leak if possible. It could be the pinion, vent plug, fill plug, rear cover or rear cover drain (if equipped).
95LTXZ28
04-13-2012, 03:16 AM
Thanks for the suggestions guys. I called up the previous owner of the car and he said the reason it is leaking is because he overfilled it last time he did a fluid change. I drained it down to the fill plug on the side and I have no issues now.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
