Dynamometer Results & Comparisons - CSP Built LS2 GTO, 227deg HR, Ai 226cc CNC'd 243's - 476/409
Advanced Induction
04-07-2012, 01:43 PM
A northeast shop, CSP, has been getting great results with their packages that include our CNC'd GM 241, 243, etc. heads. Thought you guys might like to see some as I sort through results guys have been kind enough to send in.
LS2 M6 GTO
Primary details:
Ai 226cc CNC work (http://www.advancedinduction.com/LSX/AiLSx226ccGMLS2Head.php) on GM 243 heads
Lunati 227/235 .620" 114
Ported GM LS2 Intake Manifold
Full Exhaust w/ Cats
LS7 Clutch
Built & Tuned by Andrew @ CSP
http://www.advancedinduction.com/Dyno/CSP_Ai226243_Lun227HR_LS2.jpg
Original GTO forum thread by CSP:
http://www.ls1gto.com/forums/showthread.php?t=436788
Hope you guys like it!
-Phil
reeperz28
04-08-2012, 08:01 AM
Pretty awesome numbers on stock ls2 intake ported. Hope to get close to those numbers with my 243 AI setup :)
Gordon0652
04-08-2012, 08:18 AM
Nice numbers!
s346k
04-08-2012, 01:11 PM
holy shit look at that tq curve.
andrewzpsu
04-11-2012, 05:04 PM
And it drives really amazing. Just like stock.
We've got a special going on for all LS engines for the head install. We will send out our cores to get ported for you so you have minimal downtime - just the time it takes to install and tune. This does not apply to the LS7 (as we don't have a set of those heads). We have LS1, LS2, and LS6 heads in stock ready to be sent out.
You can combine this special with a cam install and save some pretty good labor there!
Advanced Induction
04-16-2012, 06:12 PM
Many guys do - some built by highly experienced shops tend to do it out of the gate, while others end up working at it to identify areas of their setup they can refine to get things up to potential. Either way, the potential is there.
I'm sure it drives quite well, I try and stick with cams in this size range since they lope a bit, but with proper calibration have essentially stock manners. That is especially the case when guys retain OE clutches.
If we schedule work ahead of time knowing when heads will be delivered, especially if it is machine work only, then I can typically turn them around in far less time than normal. :)
Thanks for your hard work on it!
-Phil
I like small cams that put up big numbers. It's all win.
yonerhottlt1
04-30-2012, 04:47 PM
Great results for the setup!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
