Carbureted LSX forum - MSD 6010 No start
View Full Version : MSD 6010 No start
Beeterolds
04-07-2012, 04:30 PM
Well today was the day I would try to fire my 5.3 so I thought..
Cranked and nothing... before you guys go over the basics, I already beat you to it..
Freshly charged 1000 CCA battery (jumped while hooked up to my friends running Jeep)..
I tried it directly from the 12v Lead from the Old HEI AND directly to the battery.. I have a good ground right to the coil bracket
I hit the key and the tach moves a bit which indicates the box is getting juice.. but the tach does NOT show any cranking RPMS at all...
The engine is cranking over just fine, Hell its cranking over faster than the stock 4.8 in my truck!!!
It just wont fire no matter what I do.. maybe a bad crank sensor? the motor is a stock 5.3.. the bottom end has not been tampered with, nor has the reluctor ring been touched.. the sensors are stock and the engine was removed from a running Tahoe...
The box is a newer model.. made in 2011 I know the early ones had issues but I would assume these later boxes have been updated..
What should I look for next?
GNCLONE
04-07-2012, 05:22 PM
Well I'd say the box is bad - BUT might be something silly.
1. Do you know for certain there is no spark? Check for spark (could be no fuel)
2. If it is turning over as fast as you say then there is obviously good ground, the motor mounts you made are probably a good ground to the frame. Do you have a frame to body ground? Is the box grounded to the body or frame?
3. Is it popping, like it wants to start? Does it smell like raw gas?
4. I'd disconnect everything related to the box and re-connect it all.
Beeterolds
04-07-2012, 06:14 PM
Hey bro, O yes sir we tested for spark.. No spark.. I shot a wisp of ether down the throats to at least get a pop or burp..but nothing.. stone cold nothing...
I hope the box isn't bad as its a new box and an updated version... The ground is direct to the intake and the ground cable is from the head directly to the battery.. I could always run a ground directly to the battery from the harness..
I plan on pulling the plug on the crank sensor and testing it with a Multimeter... I assume you plugged yours in and she fired right up!
Beeterolds
04-07-2012, 07:26 PM
Ok I've made some progress... The grounds are permanently connected to the battery and I removed the plugs to crank it over for increased speed... and voila! Bright ass spark in all holes!...
Sadly I cant start it tonight cause the garage is a part of my house and my womans kid is sleeping right above where im farting around :mad:
No matter how good you think your grounded its NOT good enough!!!
GNCLONE
04-07-2012, 08:00 PM
That's good news!
Let the kid sleep - you waited (what a year?), what's one more day?
ZONES89RS
04-07-2012, 08:44 PM
Late night starts blocked by family and neighbors....as is life. Lol
Beeterolds
04-07-2012, 09:27 PM
That's good news!
Its been a good 6 months thats for sure!!!
Ya Christ wont be the only one celebrating his day of resurrection tomorrow :angel:
1953/5.3
04-07-2012, 09:44 PM
Glad to hear you got the problem figured out, can't wait until I get to the point.
ZONES89RS
04-08-2012, 06:36 AM
6:35 am, good enough time to start it...lol
Prorac1
04-09-2012, 06:27 AM
From my experience ALL MSD products should be grounded directally to the battery. Thats where ive grounded all of mine since having problems years ago. Eric L
ZONES89RS
04-09-2012, 05:21 PM
I ground all my ignition controllers to the engine.
Jared_Williamson
04-09-2012, 05:52 PM
Were you ever able to fire it over the weekend? Updates!
GNCLONE
04-09-2012, 06:47 PM
MANY guys do a great job building an engine, and do a terrible job with the electrical system. Eric is right, GOOD GROUND!
Unfortunately, my batt is in the trunk and I figured there would be more resistance running a ground wire all the way back there.
Pop N Wood
04-09-2012, 08:09 PM
Well I know no one wants to hear it but if you never ground anything to the body then there wouldn't be any issues with grounds. Run two wires to every load and all the confusion is avoided. GM got it wrong when they tried saving a few bucks by using body panels instead of ground wires.
Beeterolds
04-09-2012, 09:02 PM
No updates yet guys, I know its a simple task of turning the key and spraying a little gas down the hole but cause of the holiday I haven't had a chance... Tomorrow after work is go time I think... wish me luck
I plan on running the hot lead right to the battery as well via relay and fuse.. that way I eliminated any chance of voltage drop
ZONES89RS
04-09-2012, 09:35 PM
Good luck man, should be fine.
Prorac1
04-09-2012, 10:55 PM
Hope it goes well, keep us updated. Eric L
GNCLONE
04-10-2012, 04:21 PM
All the other manufacturers do it too!
Pop N Wood
04-11-2012, 05:23 AM
Not the Japanese. If you notice any computer controlled item doesn't either.
Beeterolds
04-11-2012, 10:36 PM
We started it up last night! Ill have video soon, tossed a little gas down the carb and boom she fired right up!! Yup im happy
GNCLONE
04-12-2012, 05:55 AM
Cool! congrats.
Yes, fuel is needed :) lol
ZONES89RS
04-12-2012, 01:27 PM
Good man, how she sound?
