LS4 Performance - stroker kit for ls4
View Full Version : stroker kit for ls4
06GPGXP33
04-07-2012, 09:55 PM
does anyone if there is a stroker kit for the ls4? just curious to know if one was made? and i also heard the ls2 kits will work for the ls4... let me know
fubar569
04-07-2012, 10:15 PM
The LS2 kits will not work.
We have the small(er) bore block. Our crank is 13mm shorter than a LS crank. Cams and intakes will interchange.
Your closest application would be pistons and rods for a truck 5.3 with a custom stroker crank.
Sadden
04-08-2012, 01:11 AM
Theres been talk about it , depends on how big you wanna go , the crank can easily be machined to our needs.
99slpws6
04-08-2012, 07:50 AM
And also depends on how deep your pockets are.
neilownz
04-08-2012, 09:16 AM
Minimal displacement increase for the money. See how much a custom block is if you have cash to burn.
SSCoop
04-08-2012, 10:00 AM
I made a post about this when I had my SS and I was told that having these engines bore and stroked were useless unless you were planning on spending massive $$$. Get the 5k turbo kit, a cam, beef up the transmission, some ported heads, the ls6 throttle body, some headers if you don't have them, and a hand held tuner. That would be a lot less than getting this engine bored and stroked
