How durable/reliable is the Stock flywheel?
Old 04-08-2012, 11:16 AM
badazz81z28's Avatar
Default How durable/reliable is the Stock flywheel?
Is this one of those components that need to be swapped out?
Old 04-08-2012, 11:23 AM
crainholio's Avatar
I have yet to see a factory or GM replacement flywheel fail, even after two cleanup mills at the machine shop during clutch swaps.
They're iron, so they give up some of the lightness that aftermarket alloy or aluminum flywheels bring to the table.
They're not SFI rated, so if that is needed then it's an easy decision.
Old 04-08-2012, 11:55 AM
Thats good, I wasnt sure if it was going to explode on me with 500hp.
Old 04-08-2012, 12:42 PM
crainholio's Avatar
Plenty of other things to break during hard launches...the clutch pressure plate and/or disc would be my concern.
