Spring upgrade
Spring upgrade
Comp 226/232 LSA 115 blower cam .568/.574 lift
Comp Cams - GM LS Dual Spring Kit
w/Springs/Retainers/Seals .650 Max Lift
COMP - GM LS-Type Trunion Rocker Retro Upgrade Kit
Smith Bros. - 5/16 X .083 4130 One Piece 7.400 pushrods
Lifter buckets
LS7 Lifters
LS2 tensioner
GM Water pump
GM Oil pump
Katech - C5R Timing Chain for GM LS Series Engines
GM - 1998-2002 Camaro V8 Damper
GM - LS1 Water Pump T-STAT Housing
GM - T-STAT Bolts
All was installed by JDP motorsports in Utah. Car is currently being dyno'd. Will report back with numbers.
Lifter buckets
LS7 Lifters
LS2 tensioner
GM Water pump
GM Oil pump
GM - T-STAT Bolts
