H/C with D1SC questions
I currently have PRC 2.5 LS6 heads milled .020" with a 231/234 .643"/.598" cam @ 10:6 compression. Made 442hp on mustang dyno. It's a very fun street car but I can see myself wanting more down the road probably in a few years but would like to start planning it now. I'd really prefer to keep it around 550 - 575rwhp.
- Are my heads ok for a D1SC kit?
- I'm guessing the cam would have to be swapped out?
- I'll be getting MWC 9" probably next year, are 4:11's still ok?
- Is the Ractronix F99 hotwire kit suitable?
- Will I need bigger injectors than 42lb?
- Will I have to do any internal work to handle the HP?
Any other opinions/suggestions welcome....Thanks!
LS1Tech Sponsor
The setup is fine. I just do the D1 at 10-12lbs and add a methenol system. We put blowers on alot of H/C cars like yours, recently an 01 Vette with AFR's (11.2-1) and a 228 cam. 10lbs made 650rwhp with methenol.
If you have a decent tuner there is ussually no issues.
Captain Double Post
Yeah i think you will be fine as long as you keep things on the safe side,i have seen alot of setups that you wouldnt think it would do well with a procharger but they do,my set up isnt the best for boost but i plan keeping things on the safe side untill i can change some things
def ditch the cam. boost likes longer gears. 342's or at most 373's is my best guess. those heads are fine, but 317's are indeed gunna outflow them. you could sell em and get some 317's dirt cheap and put the money towards fuel. do at least some head studs and gaskets.....and a safe tune, if you have the ls6 intake unblock the steam vents in the back. its always a gamble on stockers but some have lived. vengeance racing did 800+ rwhp with a rearmount on his c5 ls1. temps and tune are crucial.
Thanks! Not too bad for a budget build.
So some say cam is ok with a good tune, some say to switch.
