Cadillac CTS-V - usa spec?
tommycompton
04-08-2012, 06:40 PM
Installed a usa spec ipod adapter but how do I get it to direct mode so I can control songs from my Iphone?
Instructions suck ass. I have almost no Idea how to select playlists from the head unit. I would rather use my Iphone for controls, but have no clue how.
jweymar
04-08-2012, 09:50 PM
Press the right bottom button on the nav unit, it will then switch to direct mode.
nikon
04-08-2012, 10:05 PM
Read the instructions again..it explains how to setup the right side buttons to whatever you want
tommycompton
04-08-2012, 10:49 PM
I'll try all the above, thanks. I've been finding the instructions rather confusing, and nothing really to say how to get to direct mode
FuzzyLog1c
04-09-2012, 05:08 AM
You need to specify which unit you have. If it's the PA15-VETTE (the best one), all you have to do is hit F5 (fifth button from the top on the right hand side of the screen).
tommycompton
04-09-2012, 10:26 AM
Yeah it's a pa15-vette. I'm going to try the suggestions today hopefully I get it figured out
FuzzyLog1c
04-09-2012, 10:33 AM
Just hit F5. The screen will say DIR.
tommycompton
04-09-2012, 11:55 AM
Not working for me. I think I may have changed f5 to a preset, now I don't know how to change it back
tommycompton
04-09-2012, 12:20 PM
If this helps here is a picture of how I messed up my side button presets.
http://i36.photobucket.com/albums/e29/tommycompton/photo.jpg
jweymar
04-09-2012, 12:49 PM
not sure looks like it would be the 6th button, no? Might have to reset the pa-15
nikon
04-09-2012, 12:51 PM
From the manual... Basically disconnect the ipod then press and hold seek, then press and hold the button you want the function assigned to.
The formatting screwed up when I copied it...heres the manual, instuctions on page 9
http://usaspec.com/userfiles/editor/file/pa15vette_manual_20100520_webuse.pdf
Step 1- Complete PA15-GM wire connection steps described in Section 4 of this manual.
this manual.
Step 2- Disconnect iPod from PA15-GM!!!!
Step 3- Press XM button to find XM1 on radio.
Step 5- Long press SEEK button until the letter PLAYLIST is shown on the text line
Step 8- Touch-and-hold anyone of the not-yet-programmed preset buttons until
Step 7- Short press the SEEK button and next function will appear on the text line
Step 6- Touch-and-hold anyone of the 6 preset buttons until letter PLAYLIST
where CH (channel number) is displayed. Note: before the SEEK button
appears on the preset button.
the name of the function appears on the preset button.
is long pressed, letter “ iPod ” is shown on this text line.
If your radio’s touch screen is the same as in the Example B above,
go to Step 11 of this section first.
where CH is displayed. Note: PA15-GM may provide more than 6 function and
you can use only 6 of it due to radio has 6 preset button only.
tommycompton
Nah I don't know how I did it, but the iPod toggle sets a preset equalizer setting lol
FuzzyLog1c
04-09-2012, 01:18 PM
Whenever you set a preset, the current EQ setting is associated with that preset.
tommycompton
04-09-2012, 02:46 PM
Got it!!! Had to call tech support to walk me through it. And my mistake it's actually a pa50-vette . Works perfect now, thanks guys
