Fox electrical
Old 04-08-2012, 08:51 PM
06colorado's Avatar
Default Fox electrical
Been searching for hours on this. When you did the swap how did you get the headlights/turnsignals to work? I know the chassis harness is seperate and all i get is the dash lights to come on, when i turn the lights on the turn signals light up and so does the bright light singal but niether work. ANy one have pictures? Car is an '88.
Old 04-08-2012, 09:01 PM
Revoroller's Avatar
Must be something in your wiring, my 89 didn't have any issues when I pulled the factory engine harness.
Old 04-08-2012, 09:08 PM
zipster's Avatar
Sounds like you are missing the grounds, I would start there.
Old 04-08-2012, 10:58 PM
06colorado's Avatar
That is good place to start. I'll check it and get back, thanks guys
Old 04-09-2012, 09:16 AM
Chrome_Rust's Avatar
in the front corners near the lights on driver and passenger sides there are 2 grounds, one for left and right lighting. If they are not fastened, you will have the problem that you are describing.
here are the locations:
Quick Reply: Fox electrical
