Carbureted LSX forum - any one using a ms4 or tsunami in carbed lq4
Rick364ls
04-09-2012, 11:46 AM
I am just throwing together a lq4 for my 95 mustang th400 brake 5500 converter and 4:10s looking for a decent setup till i build my 408 was wondering what would be a good shaft top use for that set up just for now dont care about street manners lope or drivability. i know it will be lower compression but i am hoping the converter will let it come up top for decent power. i would also like to use this cam later in the 408 build I realize it may not be ideal for the 364 any suggestions or is there a better carb application cam shaft available.
ZONES89RS
04-09-2012, 05:23 PM
Will work bad ass, too small for a 408 if you want to get the most from that many cubes.
Rick364ls
04-09-2012, 07:51 PM
Thanks for the reply
ZONES89RS
04-09-2012, 09:34 PM
Your piston to valve clearance with a lq4 will probably be fine as well.
b_evans06
04-10-2012, 05:34 PM
I run a tsunami on a cam only lq9. Even with flat tops there is no ptv clearance issues. Makes good power and has a wide power range. I run it with a 4k stall and 4.30s.
Rick364ls
04-10-2012, 07:08 PM
Evans. What chassis are you running. Any time slips?
b_evans06
04-11-2012, 08:55 PM
It is an 84 cutlass. Best time to date has been a 7.35 @96 with a 1.61 60
rail2k
04-11-2012, 10:16 PM
any soundclips with the lq9
b_evans06
04-12-2012, 10:18 AM
http://www.youtube.com/watch?v=IoR9UEsC6cs&context=C43b3985ADvjVQa1PpcFMiWN6FLOkUYhglm5AjyGdK KQWEOyHo1Y0=
correction on the time. New best tonight of 7.07 at 97 1/8th and 11.17 at 119 all motor pass. Sprayed it a 150 and it went 6.58 at 107 and 10.37 at 120 on the rev limiter.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
