Nitrous Oxide - No2 controler suggestions
View Full Version : No2 controler suggestions
indyjax88
04-09-2012, 01:27 PM
Im new to the No2 game and am lost when it comes so what controler to use... Im running a heads cam ls1 6spd. Prolly a dry 75-150 single atage system. Ive heard good things about hsw but still not sure whats just a gimmick and what really works...
Silver408z
04-09-2012, 04:03 PM
I have the Harris Speed Works Micro Edge+. It has alot of the things I wanted for the safety stuff. Window switch, wide open throttle, fuel cut, gear lock out and progressive control. It probably does more I just cant remember it all now. I dont have much experience with it yet because I need to upgrade my fuel system for the nitrous. I was running way to lean on nitrous.
indyjax88
04-09-2012, 11:34 PM
from what u have used so far is the micro edge plus worth purchacing in your oppinion?
derekbuckner1
04-09-2012, 11:35 PM
thought HSW went out of business? i wanted to get a microedge but went with a NOS mini controller. simple and easy to setup. not too bad on the wallet either
derekbuckner1
04-09-2012, 11:36 PM
to my knowledge the plus is just a progressive controller, right?
if you are staying with a small shot, do you ever even intend to bring it in gradually?
itsslow98
04-10-2012, 12:00 AM
I had the regular microedge and was VERY happy with the controller. Compact, good display and it worked flawlessly.
dnkynrbk
04-10-2012, 07:55 AM
I would call Nitrous Outlet and let them help u with a controller. That way they can help u get one that fits your future. Goals with your car. I have their progressive. Controller. In both our cars.
indyjax88
04-10-2012, 10:26 AM
What features are a must? Im assuming a window switch function would be a good idea...
Midnight02
04-10-2012, 11:21 AM
Love my FJO Mini controller. Window switch, WOT switch, 1st gear lockout, progressive ramp rate, etc -- works smoothly and very easy to customize with the laptop (connects via USB setup) and the software is very simple to use.
Skraight
04-10-2012, 01:00 PM
Dynotunenitrous has a pretty cheap WOT, window switch controller thats easy to work with.
Silver408z
04-10-2012, 10:40 PM
I believe the + is the progressive addition, I plan to have a 200ish shot on the car. I want 700 rwhp and 700 rwtrq on the bottle. If I can hook the full 200 shot I wont use the progressive part but I think I will need it.
I actually bought my microedge used ($125) and then sent it back to Harris to have the + upgrade performed ($140 I think). So I have a totale of $265 in my microedge +. They are still in buisness but they only communicate through email. Not the best way to communicate but the transaction went fine.
I have very little use of it so far. Less than half a bottle while starting to tune on the dyno and we realized I dont have enough fuel. I talked to several people who used the microedge + and were very happy with it.
indyjax88
04-10-2012, 11:56 PM
What about the controlers that claim to have various safeties built in... Do the really work?
indyjax88
04-18-2012, 01:39 AM
Bump still not sure if its woth the cash...
wreckwriter
04-22-2012, 10:33 AM
NOS Launcher.
gi8e7oi825
04-22-2012, 12:58 PM
I use NX's Maximizer II. Paid twice what the Maximizer 4 goes for new, and it seems to have fewer features, but I worked many long, hard, minimum wage hours for that! lol
It does what I want... auto-bottle heater control, lean cut-off (based on wideband input), controls two stages (my fuel and nitrous on separate stages to mitigate the lean-spike), ramps based on RPM, rolls into the ramp based on throttle position. There's a lot more stuff I don't use, like auto-bottle opener, auto-purge, boost cut-off, something with what gear you're in, ignition retard, etc. I don't feel like figuring that out though.
Fbodyjunkie06
04-22-2012, 03:40 PM
I would find whatever is the best deal in the classifieds.
I was just looking through the ads yesterday and there were over 15 ads on progressive controllers for sale.
There was a micro edge in the classifieds for 125 and that included everything the guy above paid 265 for.
Buy it used they don't wear out.
indyjax88
04-23-2012, 02:59 AM
Hey thanks all this really helps me know what im looking at. ill post up when i get the system purchaced and post any questions i come up with
thanks again
Phantom
04-23-2012, 11:44 AM
I use a Dynotune progressive right now. It works very well for the money. Simple install, has always worked and has 12v output for various options. I use a 12v output for my step retard on my MSD. Works great.
I will probably be switching to an NX unit in the near future.
4bangermustang
05-02-2012, 08:14 PM
I have a FJO setup. I like it a lot. But, it recently yook a poop and according to FJO can not be sent in to be repaired due to the way it is built :(
