Dyno Guesses & Bench Racing Forum - What is the potential ?
Black z28 99
04-09-2012, 04:18 PM
Hi,
Car: 99 Z28 T56, Stock gear
Mustang Dyno :
- Max WHP : 346 @ 6345
- Max WTQ : 320 @ 4900
1st run / Second run
R/T : 0.867 / 0.468
60' : 2.892 / 2.681
1/8 : 9.483 @ 84.46 / 9.218 @ 86.00
1/4 : 13.956 @ 109.90 / 13.649 @ 109.47
I was shifting just under the cut off (around 6400)
If I launch properly... what is the potential?
Thanks!
02'Andy
04-10-2012, 12:04 AM
If it's got everything listed in your signature, there's no way you shouldn't be in mid to low 12's (maybe lower depending on cam size), especially for an M6.
I'm also a little concerned about your dyno numbers, even for a mustang dyno. I'm making 345 rwhp and 360 rwtq (dynojet) through an A4 with just bolt-ons. If you've got an aftermarket cam in your car, you're missing quite a bit of power somewhere.
Out of curiosity, what kind of tires did you do those runs on? That will have a lot to do with it too. Might make you spin more and lose a lot of time trying to get them to hook.
Black z28 99
04-10-2012, 03:41 AM
Thanks for the comments
With Headers, Exhaust, Air Box/Lid and a tune I was making 305 rwhp (Mustang). My understanding is that the 99 heads are the bottleneck which limits the full potential of the new cam (231/234 .599/.648).
Tires are Nitto NT05 but it is still cold here in Montreal (around 45F) so traction was an issue.
I need to find the best launch and shifting point.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
