Paint & Body Work - Painted my wheels and lights
jbqualls
04-09-2012, 07:51 PM
I decided to see how long paint would last on these wheels. If it starts looking like crap I will take them to be powdercoated. I also used VHT Night shade to paint the lights. I am going to have the windows tinted this week as well. Here is the final product, although it is very dirty. I have been washing it about every three days and I can't keep the dirt off of it. I've had it about two weeks, and just did the paint over the weekend. I have already had people offer to buy it :), although I still think it needs a lot of work to look sharp.
http://i836.photobucket.com/albums/zz285/merfal/DSC_0022.jpg
http://i836.photobucket.com/albums/zz285/merfal/DSC_0020.jpg
Mtownls1
04-09-2012, 07:55 PM
sharp man it will look really good when windows get done
imo i would powdercoat you tips aswell, and maybe shoot some clear on the taillights to give them more of a shine..did you sand them when you sprayed them?
and if paint doesnt last long on wheels you could plasti-dip them it lasts pretty good i did my grill on my truck and i powerwash it,and it holds up well
jbqualls
04-09-2012, 08:00 PM
I am upset about the lights a little because they aren't shiny. I sanded and prepped everything well, and I put clear over everything as well. The lights were shiny until I sprayed the clear on them; maybe I'll sand it off and try again when I have the time.
I thought about the plasti dip, but I wanted to experiment and see if I could get a rattle can paint job to turn out.
christiandoy
04-09-2012, 08:02 PM
looking good man!
chaman
04-09-2012, 08:07 PM
This murder out look is getting played out. Looks good though.
stevesfbody
04-09-2012, 08:19 PM
Buff and polish the lights and see how it comes out
jbqualls
04-09-2012, 08:21 PM
I thought about that, but I haven't seen any cars around me that are all black. I prob wouldn't have done it if there were any like it around me.
jbqualls
04-09-2012, 08:23 PM
I will try that.
jbqualls
04-09-2012, 08:24 PM
Thanks for the compliments :)
stevesfbody
04-09-2012, 08:43 PM
Nothing nicer than a black WS6 with the right supporting mods :D
soco80p
04-11-2012, 05:06 AM
Not bad at all
ramairetransam
04-11-2012, 07:44 AM
the rims okay , the tint sweet , take the vht off those lights , the look perfect left alone .
216StealthSS
04-11-2012, 07:47 AM
looks great! window tint will make it 100%, all my camaros had black rims, never was a chrome guy. i had my wheels painted and baked, seem to hold up pretty well.
Mtownls1
04-11-2012, 06:16 PM
i actually did my ford f250 in the ''murdered out look'' i did blk cab lights and blk xd wheels and 2.5% tint all the way around. but back on topic lol i bought a aftermarket set of taillights that looked ricer becuase they were cheap and i was tinting them, i did not sand mine i just cleaned them really well and i must say mine came out shiny and about a year and a half now and still look really good. but you really probably should have gotten another set to keep the originals for inspection..once again my opinion only..and i bought my car with blk wheels i dont like the blk on blk car look like i do my truck
critical.in.ga
04-11-2012, 07:42 PM
-Make sure you got a few good coats of clear (light coats, slowly build it up) and let em cure for atleast 24 hours
-Wetsand, start with 1,000 grit then 1,500 and finally finish with 2,000 until they have a uniform "dull" look, should appear to be a greyish color at this point. (just dont go through the clear, which is why u rlly wanna build it up with a few good coats)
-Buff with a foam pad using some type of compound
-Buff with a softer foam pad and some type of polish
-Wax
-Finished, this will give you that top notch glassy look you are after. :D
CamaroSS27
04-11-2012, 08:39 PM
Looks good bro
merfal
04-12-2012, 07:51 AM
I am the OP; I wanted to change my name.
Thanks for the compliments. Like some have said, I'm not too sure about the taillights. I am definitely going to try to get them to shine. If I can't get them to look decent I am going to go back to stock.
I looked up the law in NC and I am legal with the lights the way they are. I printed the law out and put it in my glove box in case I get harassed because of it.
bad_408_vert
04-12-2012, 09:27 AM
Heater hose is another budget mod that will make the car look lower in the rear.
Are those exhaust tips ok factory catback?
critical.in.ga
04-12-2012, 10:18 AM
Did you see my post above? Its not a question of if they will shine as long as you follow those steps.. they will match the shine of ur car perfectly.
merfal
04-12-2012, 04:33 PM
I will definitely do this. I have enough clear on there that I could prob do it without adding anymore, unless you think I should.
Bad_408 - I have an SLP catback on the car.
critical.in.ga
04-12-2012, 08:51 PM
Jus dont go crazy sanding at it and it should be fine. U can use a hose to keep a steady stream of water flowing over it while ur goin at it.
Jr.Samples
04-13-2012, 10:41 AM
I sprayed two light coats of that VHT on mine and buffed them with meguires swirl remover. I didn't want them too dark. It looks ok .
merfal
04-22-2012, 07:46 PM
I was worried about not getting them too dark as well. I ended up spraying on four coats and I don't think it's too dark.
