bigblock4-speed
04-09-2012, 08:48 PM
I am selling my camaro, and the gentleman is picking it up this thursday this week!! What would it be worth to you? Did i get good money out of it?
Here is the write up on it:
I have decided to sell my 2001 SS camaro. It just turned 38,000 miles the past summer, and has been garaged its whole life, by me and previous owners. I have owned the car since November 2007, and it had at the time 29,890 miles. All original paint, true ss car with t-tops, leather interior. Everything that is factory works! Cruise, power seat, power windows, wipers, factory alarm, all lights, air conditioning blows ice cold, heater, etc. Car This car was set up for a fast, sleeper car- while still maintaining all around performance and mpg!
Some of the aftermarket parts are as listed, and were added to the car when it had 25-27k miles. This is not a back yard build ls1 car, all performance parts and add ons were done by hutter performance in chardon, Ohio.
Ls1
D1SC Procharger current setting is 7.8 pounds.
Twin Intercooler, all custom from hutter performance, fits, and looks great.
Procharger stainless air box, ported by Ron and the guys@ hutter performance.
8 rib setup on blower.
Procharger install included pump, aftermarket injectors and Ati damper.
Comp cams ls1-3718R-HR114
Specs on blower cam:
Advanced duration: Int 283/Exh 283
Duration @.50 Int 230/Exh 230
Lobe seperation: 114
Valve lift 572/572.
This is a very correct blower cam to use with this ls1 application.
Comp cams Dual springs. Spring seats, Tit retainers, seals.
3/8 pushrods
Cloyes Adj timing set with hd chain.
Motor is a stock bottom end, stock ls1 325hp aluminum heads.
Do research, these motors have strong bottom ends, and are able to support 800hp.
Rearend:
Moser 12 bolt rear end. Built to the hill..
33 spline axles
Truetrac 4.11 ratio
1350 series yoke
Alum girdle
Ya, its 4,000 through moser.
Transmission:
All mounts have been replaced with solid motor mounts. You can hear the drivetrain, but was done for performance.
Spec 4 clutch, throwout bearing was all serviced at 25k.
Shifts great! Hurst short throw shifter, with line lock.
Spohn Transmisson mount/driveshaft loop/torque arm mount.
Chassis:
Spohn Extreme duty Driveshaft, 1350 rear
Driveshaft front safety loop
Chrome moly spherical rod end 5/8 x3/4
Lower control Arm relocation Brackets for moser rear.
Aftermarket Rear sway bar Mounting kit 3' od axle tubes.
Adjustable heavy duty tubular torque arm
Spohn sway bars 32mm front.
1 inch sold 4140 chrome moly rear sway bar.
Sway bar spacer kit.
Sub Frame Connectors
Interior:
All stock, no gauges to make it look like a race car. Has a shift light in pillar (never hooked up) a switch built in the ash trey for electric fans, and line lock.
Interior is a 9.5 out of 10. very very small wear on driver seat- other than that- very clean, very well kept interior.
Exhaust:
Was in a Chevy Rumble magazine for the exhaust.
All custom stainless 3.5 inch by stainless works in Ohio.
Beautiful, poly mounts, all tig welded, all custom long tube headers stainless. Nice set up.
Brakes:
Wilwood disc brakes 6 piston up from
Wilwood disc brakes 4 piston rear.
Both are wilwood slotted and drilled rotors.
Wheels:
Custom Budnik 18 inch wheels.
18x 11 rears and 18x9.5 fronts, HAMMMER built in the USA la la land. Nice set of wheels..
Ok, now performance. Since you now know, it is procharged- before it was procharged with a set of slp headers and y-piple and high flow cats, on a mustang dyno it pulled 365rwhp @ 6100rpms. 370foot pounds torque.
When installed D1SC, On a mustang dyno at hutter performance.
543rwhp @6800rpms, 518 foot pounds of torque.
At the crank- around 650hp.
This was the setting of the original owner, who i have talked to and was wanting something that was reliable, and ran efficiently. With this current tune, the car averages 18-19mpg around town, and averages 24-25mph out on the road. I did take the car to westvirginia 2 times, both times averaged 26mpg! Runs 70mph @ 1800rpms, 6th gear.
This car is able to put more power to the rear wheels, just no need for what i use it for, and for what it already does. Hutter performance did set the unit when building the car @ 12psi- just to see, and it made around 680rwph.
With being a camaro nut, i have taken the car to the track a couple times, first was with a set of pilot pros "street tires" ran a best of 12.20 @ 127mph- with a 2.00 60'- yes, it was spinning.
I bought a set of m/t 305/35/18- wow a difference! My best time was a 11.50 @ 129mph- 180 sixty - left very softly- this is a mid to low 10 sec. street ride, but i drive it and enjoy it on the street. Car has been taken care of, washed, waxed, polished, etc- and since ive owned it i have put around 9,000 miles (in 4 years)
Ls1
Valve lift 572/572.
3/8 pushrods
Rearend:
33 spline axles
Truetrac 4.11 ratio
1350 series yoke
Alum girdle
Transmission:
Chassis:
Interior:
Exhaust:
Brakes:
Wheels:
