Howards tie bar lifters?
I'v been doing a bit off research to find out if these Howards cams tiebar lifters i have been supplied,
number 91166 are good for my setup?
Mostly street driven will see odd track from time to time,
Specs are 2002 5.7 ls1 stroked to 383, cam 235/243 .621, .624 113 lsa power band off 2200-7200 rpm, lunati .660 lift dual valve springs. using factory 1.7 rockers with comp trunion upgrade.
And if so which Morel lifters are they the equivalent too?
Was after Morel 5206's, been advised that the howard lifters are made by Morel which i have found through some searching.
Any help appreciated before i decide to put them in.
