Generation IV External Engine - DOD Delete Question.
View Full Version : DOD Delete Question.
LCW
04-10-2012, 10:45 AM
Will any valley cover work when doing a DOD delete? If so, then why is the ls2 or ls3 cover preferred?
S10xGN
04-10-2012, 08:03 PM
Yes. And it's smooth on top, lacking the oil passages in the casting.
LCW
04-11-2012, 04:00 PM
Thanks, for the reply. Do you know why the ls2 or ls3 are preferred?
Edit: I am doing this for a buddy of mine. He has a 2009 Sierra.
S10xGN
04-11-2012, 08:35 PM
Again: "And it's smooth on top, lacking the oil passages in the casting." That is the reason for using it. You will also need to either tap & plug the towers or use o-rings to seal them.
