aaron564
04-10-2012, 04:03 PM
ok sounds pretty simple battery gauge goes down when useing turn signels or if i turn the wheel all the way to one direction the batter gauge will just drop down but then comes right back up if i turn the headlights on it will actually go up so i took it to autozone and had them test the alternator and the battery everything is working 100% normal. if i was to make a guess i would guess that there is power draw somewhere need some ideas or somthing and scond part to this is that the ing relay went out so i bypassd it and added a push button start it works most of the time but since then my blower motor for Heat/Ac has decided that it wants to go on strike lol so idk if i turn it on i can here the compressor kick on from the freeon i belive well thats what it sounds like but i cant for the life of me figure out why it wont blow . if any ideas thanks in advance i know my Bird needs some work .
