Drag Racing Tech - wheel studs
View Full Version : wheel studs
BuckaroooZ28
04-10-2012, 06:00 PM
at what point should i swap to 1/2'' wheels studs in the rear?
soco80p
04-11-2012, 04:54 AM
The stockers can hold quite a bit of power, but if you plan on spraying it or running slicks, it won't be a bad idea to upgrade.
BlackScreaminMachine
04-11-2012, 07:07 AM
Based on your mods, now. I have seen guys hitting 5-6 launches on slicks and you can see the studs bending. Its more like repeated launches will do the job. You just need to plan for it accordingly.
black00ssFL
04-11-2012, 12:54 PM
I've bent my stockers with 400whp, ls7 clutch, 5500 rpm clutch dumps, on a bia ply tire. I have 1/2" studs in there now.
blue99fbody
04-11-2012, 02:29 PM
i ran 12mm 3" arp wheels studs for 3 yrs @ 550-800whp with a 6spd car and hundreds of 6k rpm launches ive since upgraded to 5/8 bc i knew i was pushing the limits
1lejohn
04-11-2012, 02:42 PM
12mm Arp studs here. So far no problems.
Doug G
04-11-2012, 06:48 PM
One thing I've learned running a spool (even a tight posi will do it) is to check and properly torque the lugnuts on a reguler basis.
The constant working back and forth takes it's toll.
I've seen 5/8" screw-in studs break too (other side was loose so we figured that's what happened).
BuckaroooZ28
04-12-2012, 10:12 AM
Thanks for the input guys...I'm running 12mm extra long arp. ...launch@ 6000 on slicks....ill plan on upgrading soonish
BuckaroooZ28
04-12-2012, 10:14 AM
Oh and that's with a locker
1lejohn
04-14-2012, 04:27 PM
Thats the key. I also use never sezze on my studs. The books tell you not to but what do they know. If you don't and change wheels often you will gall one. Just adjust you torque setting accordingly.
