LS4 Performance - '07 Impala SS clips after having it tuned.
critical.in.ga
04-10-2012, 06:03 PM
http://www.youtube.com/watch?v=BpuIP9g-mHs
http://www.youtube.com/watch?v=RI734RqlPWY
Barnett92
04-10-2012, 08:38 PM
You was coming up on traffic at 160??? The car sounds incredible man! Good vids, but you got a couple lights on the dash there lol.
critical.in.ga
04-10-2012, 09:07 PM
Thanks!!
I really wanted to completely top it out and I was soo close... friggin cars on my racetrack :bang: j/k lol
Yea I think thats just about all of lights, no cat is the check engine light and aftermarket wheels is the tire pressure sensor light... and then I had the traction control off too, yet another light haha.
SSCoop
04-10-2012, 11:22 PM
The car sounds awesome! If I were you I would get a big ass transmission cooler
critical.in.ga
04-11-2012, 11:53 AM
Thanks!
Any recommendations on the cooler? Its a pretty straight forward install too right? Jus tap into the trans pan and run the lines to the cooler?
SSCoop
04-11-2012, 01:03 PM
Thanks!
Put it like this, get the biggest one you can put under there. A transmission shop would normally install it for like 100 dollars.
critical.in.ga
04-11-2012, 01:21 PM
But its free if I do it myself! Jus never done one before.. (or had the need to until I got this car lol)
ghetto joe
04-11-2012, 01:39 PM
if it is tuned why didnt you tune out the cat code?
critical.in.ga
04-11-2012, 01:51 PM
Please explain how I do that.. I didnt see any options in the tuner for it.. but I woulda if i knew i could!
NVR_ENUF
04-11-2012, 01:52 PM
I haven't looked too closely at the LS4, as I didn't install my trans cooler yet.... but the way I had it on my L67, I removed the trans lines from the radiator and double-clamped the flared ends to hoses going to my trans cooler, which was mounted in front of the radiator. Doing it that way keeps the trans fluid away from the hot coolant going through the radiator and isolates it in its own cooler.
Some may not agree with it, as there are a couple drawbacks.... i.e., in cooler temps (winter), it takes longer to heat the trans fluid up. Cool fluid is good, but too cold is not.
2nd drawback, is now you have hoses/hose connections that can fail and your trans would be toast by the time you realized you have a major leak.
I never had a trans issue with that car over the 5+ years I owned it as a DD...and it was probably mid-high 12sec power (13.1 @ 108 with a shitty 2.2 60' on winter tires) for most of those years.
critical.in.ga
04-11-2012, 02:01 PM
Thats seems like a good way to do it.. I live in GA so I dont really have to worry about winter months. Thanks im gonna check into that..
Brian396
04-11-2012, 06:30 PM
HPtuner?
critical.in.ga
04-11-2012, 07:09 PM
HPtuner?
superchips 2865 flashpaq
SSCoop
04-11-2012, 09:11 PM
NVR_ENUF had beat me to it lol
critical.in.ga
04-11-2012, 09:45 PM
Lol so that must be the way to go. Where is the best place to mount it on these cars? I havent really checked it out to see if there is room in front of the rad..
