Cadillac CTS-V - Upgrading the intake and TB... Fast 92 and LS2 tb... whatcha think???
NeverSatisfied02
04-10-2012, 08:40 PM
Bout to pull the stock LS6 setup off the car cause i found a local deal on a fast setup.
Its a FAST 92mm intake ported by vengeance racing that has been smoothed and painted gloss black with 3 coats of clear and the previous owner added nitrous blowouts on the bottom.
Should the ported 92mm intake be enough for my mods??
Just dont wanna jump at this if the 102mm would be better or make more power? Im assuming the 102 would be overkill though on this motor even if i do plan to go with big heads later.
LMK fellas!!
And also, if anyone has a stock LS2 TB for a good price, lmk!
ColeGraham
04-10-2012, 08:59 PM
92MM Fast will be just fine...
and BTW, you have started an ass load of threads in the last month...someone must be slacking at the gym. You Vagina!
itsslow98
04-10-2012, 09:33 PM
Ported 92 will be more then enough even if you do heads down the road. Youll see great gains from the FAST especially with a big cam. Plus you could always do direct port nitrous now!
ColeGraham
04-10-2012, 09:34 PM
This was entirely too nice...I do not approve this message Allen.
SVTconfused
04-10-2012, 09:39 PM
price on ls6 intake? not that i have any motor fund at the moment... LOL
itsslow98
04-10-2012, 09:45 PM
Your right I cant believe that juicehead is gonna settle for such a small manifold.
ColeGraham
04-10-2012, 09:54 PM
I think you mean "You're"...you rednecked, mustang driving turd...
itsslow98
04-10-2012, 09:57 PM
YOU'RE just jealous that I put my car for sale after you, sold it before you, and bought a car that will already give your next imaginery car a run for it's money.
NeverSatisfied02
04-10-2012, 10:07 PM
LMMFAO!! I literally just laughed out loud at that last comment u made Allen. haha Cole will never sell that pile of truck garbage but... I'll buy the throttle body off it! lol And i haven't been slackin at all. Just LS1tech'in between sets. lol Gotta give the people something to read.
I figured the 92 would be enough. Just wanted to make sure. I'll be picking it up in the am.
As far as direct port, i can always do that later right? I was just going to buy the 92mm plate for it that will go up to a 400 shot. Figure that will be plenty since i don't plan on running over a 200. Ill be staying on the 150 until i get a boost a pump, fuel rails and the 42lb injectors anyway. And my current zex kit only goes to a 175. Ill have to upgrade all the nitrous stuff later on. lol
NeverSatisfied02
04-10-2012, 10:12 PM
Stock intake a TB... im asking $450 for both.
itsslow98
04-10-2012, 10:23 PM
Yea you dont really need direct port, and you have to be maxing out your stock pump on 150 shot right now. You wont need injectors or rails if your just upping the shot itll be the pump that needs to be addressed. Id just do an inline 255 instead of the BAP.
NeverSatisfied02
04-10-2012, 11:10 PM
I figured if i had the motor built for it and went 300 shot or something, i might do direct port but figured it would be pointless for a 200. And yeah, they said with the 150, im at my limit. It flows enough for the 150 but anymore and it prob wouldn't keep up.
How much would an inline 255 run me?
And the stock rails should be good for a 200? I know the injectors are 28.8 lbs stock. Figured they'd be at their limit with a 200?
itsslow98
04-10-2012, 11:34 PM
Wet kit is getting the fuel from the pump not the injectors. If you had a dry kit the fuel supplied for the nitrous would be handled through the injectors.
NeverSatisfied02
04-11-2012, 12:27 AM
Oh ok. All of this nitrous stuff is new to me. Still learning lol
NeverSatisfied02
04-11-2012, 01:09 AM
Another quick question... Not that this dude would mislead me but with the fast being shaved smooth and painted gloss black, there are no numbers left on it. I can tell its obviously a fast but is there a definite way I should be able to prove that it's a ported fast 92 and not a ported fast 90? It has a 92mm nitrous outlet plate on it that im buying with it and it had a 92mm nick williams throttle body on it but because it's coming off an f-body, it's a cable driven tb so I'll need to get my own electronic tb... Which is why I'm looking for a stock ls2 tb or a deal on a used nick Williams electronic 92.
As for price... He's giving me the ported intake (engraved with VRD on the bottom proving the port work), dual stage 92mm nitrous outlet plate with some extra fittings, jets, etc, a purge solenoid, an extra 14ft nitrous line and some other misc little nitrous parts for $1080.
Seem like a good deal?
NeverSatisfied02
04-11-2012, 07:19 AM
Found a 90mm ls2 throttle body online that is said to have come off an 05 GTO with low miles but it appears to be black for $100. Assuming maybe he painted it black... I don't know.
Is $100 a fair price if it is indeed a stock ls2 tb?
NeverSatisfied02
04-11-2012, 08:59 AM
Is there a harness or anything else needed to make the ls2 tb work on my car or is it plug and play once the fast is installed?
itsslow98
04-11-2012, 09:39 PM
Yea that seems about fair, hes throwing in the cable tb too right?
100 is always what I saw the LS2 tb going for
Im pretty sure youll need a new pigtail to plug the TB in, casper sells one I beleieve im not 100% though
NeverSatisfied02
04-11-2012, 09:48 PM
No... Cable throttle body was not included since it was of no use to me but he did throw in a big NX nitrous solenoid, some braided nitrous lines, activation switch (which i needed), purge with line, etc. So i think it was pretty decent overall. Might have been able to get one cheaper but prob not worth it to wait around for one when this one was local and i can get it over and done with. Dude also said he'd install it for me for free too if i wanted to bring the car over and have him do it.
As far as the pigtail, ill order one. Think its only $50. Ended up agreeing on $80 for the LS2 tb. :)
For a ported 92 that has the nitrous blow outs installed on the bottom and its all smoothed and painted gloss black, seems like i did alright.
WeDragBody
04-15-2012, 11:32 PM
Lol Taylor is always cutting corners.. Sell me that mani
NeverSatisfied02
04-16-2012, 12:17 AM
Might have to since I'm picking up those true forged 20's now... Lol
ColeGraham
04-16-2012, 03:23 PM
You sure are dumping a lot of money into this turd...haha.
Those wheels are going to look sick on Silver.
NeverSatisfied02
04-16-2012, 03:27 PM
Lol! Its gonna look like a polished turd soon! But yeah man... Sold my lil truck I had so after paying my credit card off, I had some cash to spend on the V. I think they are gonna look sick too. Would have liked to have a photoshop done so I know what to expect but I actually think they will look better on silver with smoked lights and dark windows :)
itsslow98
04-16-2012, 09:53 PM
Putting all that money in the car with no return on investment. Kinda like Cole's car.
NeverSatisfied02
04-16-2012, 10:05 PM
Lol! Ehhh... Buying everything used at good prices isn't too bad. I'll part the stuff off when it comes time to sell it if no one wants to pay what it's worth with the mods and forged wheels.
ColeGraham
04-16-2012, 10:08 PM
Fuck you Allen...haha
NeverSatisfied02
04-16-2012, 10:30 PM
Lmao! Don't know how I overlooked that but that's funny. Cole... Sell me ur exhaust so u can get some sort of money outta that caddy truck lol
ColeGraham
04-16-2012, 10:41 PM
Nope...maybe if this was your first V1, I would cosider it. But since you are dumb enough to buy a second, you desevre your shitty ass exhaust system thats on there...haha.
NeverSatisfied02
04-16-2012, 10:54 PM
Lol! Hey... I went from an 04 to an 05 with more mods and less miles for the same price so it wasn't a bad move. I just knew better than to buy an overpriced truck motor V cause i'd really just be throwing my money away. Lol but seriously... Sell me ur system and ur exhaust lol
ColeGraham
04-16-2012, 10:56 PM
Haha...but seriously, no. You will be fine.
itsslow98
04-16-2012, 11:13 PM
At least you were smart enough to stop modding, Taylor is dropping 4k in appearance mods alone. Might get 1/3 of that back............retard. lol
:mullet:
NeverSatisfied02
04-16-2012, 11:21 PM
U worried if u remove a couple things it'll be even harder to sell Cole? Lol
Lol... Allen... Not quite $4k. If i spent that i would be a rah-tard. Lol The wheels weren't cheap but that's really the only expensive mod ive done. I figure as long as I don't drive like an asshat and keep the wheels clean and rash free, I'll get what I paid back out of em or close to it later down the road. I'd never buy brand new forged wheels. You immediately lose half of your investment once they are bolted on the car. Buying used and selling used... As long as they are kept in good shape, you can recoupe most if not all cost. I only bought em cause I think they will look sick on the silver and I wanted to be different and have something that sets me apart from the couple other V's in the area. :)
itsslow98
04-16-2012, 11:22 PM
Im just busting your balls lol. Still faster then Cole's car so thats all that matters.
NeverSatisfied02
04-16-2012, 11:24 PM
Haha! Coles car doesn't move fast or sell fast. Just slow all around. Lol
itsslow98
04-16-2012, 11:49 PM
LMAO thats the funniest thing ive read on here in a long time. I havent laughed that hard since Cole told me he was gonna ask 27k for his car.
NeverSatisfied02
04-17-2012, 12:24 AM
Haha! Poor Cole. One day that turd will sell. Lol
NeverSatisfied02
04-17-2012, 12:25 AM
Hell... I'll prob sell this second V1 before his sells lol
ColeGraham
04-17-2012, 01:53 PM
You guys are fucking dicks...haha.
We got a redneck that love crabs and juice head dumb enough to buy this car twice. Allen, enjoy paying your state taxes and living in a state that hates guns. Taylor, you should be at the gym "pumping iron" so you are better able to blow dudes on the weekend.
We will see what happens when I come to Houston for TX2K13...bring your A Game Taylor, since Allen will be too much of a bitch to show up.
NeverSatisfied02
04-17-2012, 03:21 PM
Bahaha! I'll be headed to the gym shortly so I'll be ready for just that.... No homo Lol
At least ur smart enough to know you'll still have that pile in ur garage come TX2K13! Lol I'll bring my C game and still wreck shop lol
ColeGraham
04-17-2012, 03:48 PM
My pile o' shit will be gone...I got a new deployment, going to be overseas from July '12 til January '13...with my plans, you will need your A game...haha.
NeverSatisfied02
04-17-2012, 04:34 PM
Haha! Thank god for ur sake and the sake of ur posts on here about ur stability system problems on that truck driven V of urs. Lol Now sell me the exhaust and system since ur gettin rid of it anyway. Lol
What's the plans for the new ride. I almost went the cobra route like Allen did but got a deal on this V from a buddy and couldn't pass it up. Figured I'll play with it for a bit and then find something else I wanna buy. Prob a C6 Z06 or V2 next unless I get a whipple/KB or turbo cobra.
ColeGraham
04-17-2012, 04:50 PM
More then likely a built up C6 Z06...hopefully find one that is well modded, that I will have to do minimal changes too. Hopeing to find a H/C/I/E (maybe with a S/C) with a good aftermarket clutch.
NeverSatisfied02
04-17-2012, 05:14 PM
That's sick! Exactly what I'd be looking for. I just wasn't ready to spend $40k on a car yet. This car I have now is giving me the opportunity to save some more money while having a low payment and it's still fun in the meantime.
