View Full Version : 6 lug vs 5 lug
Bertbart
04-10-2012, 09:12 PM
I'm new to cts v's so be nice if this newbie asks what seems to you old salts as silly.
I'm guessing that 2004 and 2005 V's are the only
years that have the 6 lug wheels. Are there any aftermarket 6 lug rims
available? Will other GM 6 lug wheels work?
Will someone confirm this?
That really limits wheel choice because there are
so many wheels offered in 5 lug for 2006 and up.
Can I assume the hubs can be drilled to accomodate
5 lug wheels?
Also does anyone know why they stopped using 6 lugs?
Seems like it would be stronger.
adanieljohnson1
04-10-2012, 09:25 PM
6 lug for 04 thru 07.. And you can so a search for 5 lug conversion in the cts-v section...welcome to the club bud
CTSV_510
04-10-2012, 09:29 PM
2004-2007 V's all have the same 6 lug. Other GM 6 lug wheels will not clear the brake calipers, so I don't think any of them fit. There are a couple aftermarket options, some very expensive, but recently there is a group buy on a new wheel. Check the recent threads and you'll find it.
Swapping parts to run 5 lug wheels is not simple, and I believe you lose your parking/emergency brake in the process. I only know of one person that completred the swap, but maybe there are a couple more.
They probably stopped using 6 lug wheels because it was a stupid idea in the first place. If a bugatti veyron only need 5 lugs, our cars sure as hell don't need 6 for strength.
2009+ V's have 5 lug wheels.
furbe
04-10-2012, 10:07 PM
You don't lose the parking brake. Keep your stock rotors just have them redrilled for 4.75 x 5 bolt pattern and use c5 corvette hubs. You can use V2 rotors if you open up the hub center hole and use V2 front calipers. Rear calipers are same V2/V1. V2 rotors are already 5x4.75 5x120
Bertbart
04-11-2012, 08:31 AM
Thanks for the information guys. I appreciate your time answering.
DougNuts
04-11-2012, 08:49 AM
If you use late model Camaro SS rotors do you lose the parking brake? I have seen conflicting answers to that question and it sure would be nice to be able to buy off the shelf rotors for the conversion.
Edit to answer the original question about wheels for our 6lug V:
To my knowledge there are 6 non-custom options
1) Team Dynamics wheels (Lindsay Cadillac) 18"
2) GM Accessory wheels 18"
3) Rota (Wheel dude) 18"
4) Linea (wheel dude) these may rub your trailing arms during hard cornering 19"
5) Forgestar F14 (group buy currently going on) 19"
6) STS-V wheels 19"
NOLAG05
04-11-2012, 09:09 AM
CCW's and Asanti's fit also...
LAYGO
04-11-2012, 11:51 AM
STS-V Wheels fit.
ichpen
04-11-2012, 04:48 PM
And Mille Miglia or whatever they're called. Fairly similar to accessories.
dudesweet
04-11-2012, 07:00 PM
Not sure if it's too late to take more orders, but one more option for 6-lug:
http://ls1tech.com/forums/cadillac-cts-v/1529086-forgestar-f14-wheels-entering-production-6x115-finally.html
AAIIIC
04-11-2012, 08:11 PM
www.wheeldude.com has 18" and 19" options for the 1st gen Vs. The 18" wheels (Rota Torques (http://www.wheeldude.com/catalog/index.php?cPath=457_458_459)) have identical dimensions to stock, so they fit with no issues. The 19" wheels (Linea Corsa Venetos or LC855s (http://www.wheeldude.com/catalog/index.php?cPath=457_458_460)) have caused some rubbing issues in the rear for some folks (myself included). You can find a number of threads about that, and how to fix it, here or over on cadillacforums.com.
Those new Forgestars definitely look fantastic on other cars. I'm looking forward to seeing them on a V!
wcryan
04-11-2012, 08:41 PM
the team dynamics look pretty decent IMO
Bertbart
04-11-2012, 10:02 PM
I like them too...in black.
garrettg
04-11-2012, 10:19 PM
I like the team dynamics in black, best value deal out there imo and mine came with center caps so looks fine on the street. ~22 pounds a wheel 18x9, can run 255/40 or 275/35 square setups. Might even be able to get a 285/35 to fit on the back with little to no trailing arm clearance modifications but nobody has either done it or posted about it.
AAIIIC
04-13-2012, 06:40 PM
Oh yeah, forgot about the TDs. I have a set of those, too. :)
Rota Torques:
http://www.submariner.org/thepno95/Pictures/CTS-V%20pics/abandoned5%20%28Custom%29.jpg
LC Venetos:
http://www.submariner.org/thepno95/Pictures/CTS-V%20pics/LC%20Venetos1.jpg
TDs:
http://www.submariner.org/thepno95/Pictures/CTS-V%20pics/TD%20wheels2.jpg
Bertbart
04-13-2012, 07:25 PM
I just today ordered a set of black Team Dynamics. I ordered center caps and some "Better be worth it" aluminum lug nuts.
Crazy expensive lug nuts 24 @ $5.25 ea= $126.00 worth of lug nuts.
Maybe I'm nuts.....
Or I'm getting CTS V aftermarket fever.
AAIIIC
04-13-2012, 10:37 PM
I'm not sure what would make aluminum lug nuts "worth it", but $126 is awfully expensive. Rumor has it you can spend about 1/3 that much on Ebay if you really insist on buying aluminum lug nuts. Where did you find such expensive ones?
Bertbart
04-14-2012, 09:29 AM
I found them at the same place I ordered the wheels from. They said I needed them to lose unsprung weight. They offered some of a lessor quality for $3.25 ea
$3.25 X 24 = $78.00 Maybe they just saw me coming and took advantage of my ignorance. It's a done deal now so I won't cry because I'm a big boy. One plus is if I have any problems with the wheels themselves they won't be able to say I didn't use their premium lug nuts.
One question?
Since the lug nuts are aluminum and the wheel studs are steel should I use anti-seize on the threads? I know not to use an impact and to torque them.
Scott96LT1
04-14-2012, 03:25 PM
I would probably use anti-seize to lessen risk of stripping the lug's threads, but wouldn't suggest aluminum for lug nut material to begin with. Critical component with a weaker material doesn't make sense, but that may be the engineer in me talking. In all likelihood it's probably fine. Definitely correct, don't use an impact and torque by hand.
Unsprung weight? Nothing significant will be saved by lug nut material change.
lubelizard
04-14-2012, 03:53 PM
I have only reviewed some of the ebay aluminum lugs, but the ONLY lugs I would use on my car would be from 949Racing. High quality aluminum, generous radii, properly sized hex head size, anodized, top quality and very reasonably priced. I ran the 949Racing lugs on a supercharged OT Miata without issue. You just have to have pay a little more attention to keeping the lug nuts and studs clean of debris.
AAIIIC
04-14-2012, 08:08 PM
I've used aluminum alloy (duralumin) lug nuts on my Subaru for years without any issues. But, the torque spec on the Subaru is 67 +/- 5ft-lb. I wouldn't be too keen on torquing aluminum lug nuts to 100ft-lb (the V's spec). It'll be interesting to see how that works out over time.
Keep in mind that anti-seize changes the running torque of the fastener. There really shouldn't be any need to use it, assuming the lug nuts are high quality with good threads.
TheLostDriver
04-16-2012, 01:52 PM
Biggest difference between 6 lug and 5 lug is wheel options. Honestly I kind of like the 6 lug cuz not many cars use it and it kind of deters theft a bit if you think about it
LAYGO
04-16-2012, 03:53 PM
A thief ain't gonna be that smart to check lug patterns BEFORE stealing them. He'll take them, realize the don't fit his application, then try to sell them.
ChitownLS1
04-17-2012, 05:37 PM
I am running the Team Dynamics in silver with the VMS dark gunmetal lightweight lugs (.8oz compared to almost 2oz stock).
Bertbart
04-17-2012, 05:45 PM
Those rims look very nice on your car in silver. My car is black so I'm going with black rims.
