Nitrous Oxide - HSW Microedge +
View Full Version : HSW Microedge +
SargeZ06
04-11-2012, 09:40 AM
I've always noticed a slight delay when I go WOT and the nitrous fires. The other day I looked at my voltage trigger on my Microedge + and noticed when I floor the gas, it takes about half a second for it to reach full voltage on the controller. You can watch it count up on the LCD screen. It's not an instant max volts.
Has anyone else noticed this? Have you done anything to correct it? Lower voltage trigger point? Maybe something in the tune can be changed?
BTW car is an 02 Z06.
SuperSlow02
04-11-2012, 10:16 AM
I lowered mine to either 1 or .5 under max voltage
SargeZ06
04-11-2012, 10:25 AM
My max for the TPS to be at 100% was 4.40. I lowered to 3 for now.
Just wondering if anyone else had seen this.
SuperSlow02
04-11-2012, 01:34 PM
Yep, had the same problem and mine sometimes wouldn't activate if set at 100%
SargeZ06
04-11-2012, 05:38 PM
Yeah even though my window was set for 3500rpm it would actually activate until 4200rpm because of the lag.
