427TTA4
04-11-2012, 09:03 PM
Hey fellas I need your help again I am swapping a l92 into my c5.Basically what's the easiest method to do so?? I heard of a converter box to go around the reluctor wheel swap made from someone.Last what parts ot my ls1 can be used as far as like the oil pan?? Wp?? Basically will all the front end accessories bolt right on?? Thanks
BLWN1
04-11-2012, 11:45 PM
Like to know what you find out on this...
liv2race
04-12-2012, 10:22 AM
LPE converter box, you will need to drill and tap the side of the block and relocate your knock sensors there (do a search, lots of info on here) you will also need to extend your knock sensor harness, LS2 or above throttle body and harness converter or adapter plate for your current LS1 throttle body, fuel injectors are different and you will need the converter plugs if you are running the LS3/LS7 style injectors. other than that nothing else. I am doing this right now, but with a forged LS3 (same thing basically) I am assuming you have the 58X crank and cam sensor
