Automatic Transmission - Which Torque Converter to get??
SAPO-99LS1
04-12-2012, 12:55 AM
Hello everyone in a new guy to the forum and to the Ls1 platform... So my question is what torque converter to get? And should I get an Upgraded flywheel with it... 1999 Camaro Z28 Auto . Mods are :
•SLP Flow PAC
•LS6 Cam
•LS6 Springs
•LS6 Intake Manifold
•FLP LoNg Tubes
•FLP 3" Y-Pipe
•TSP 3" Exhaust
•160 thermostat
•100 Wet Shot
sepsis
04-12-2012, 01:18 AM
Welcome to the forum.
There are several reputable manufacturers. Yank and Vigilante being 2 of the highest rated ones.
I'm going with a Yank SS3600 personally and 3.73 gears.
ULTIMATEORANGESS
04-12-2012, 05:58 AM
yes vig. and yank are very god TCs to go with.
also i recommend a trans cooler and deeper pan.
udienow
04-12-2012, 09:45 AM
My friend has a yank SS3600, has been working great so far. He got a new flexplate as well along with a trans cooler...
BAMALS1
04-12-2012, 10:01 AM
Welcome, as stated Yank and Vigilante are great. I'm upgrading to a Yank 4000 soon. I had a PTC 3600 that worked flawlessly for 70k + miles but want to give Yank a try. Really depends on what kind of performance you want from your car but somewhere in the 3200-4000 range is most common and makes a hell of a diffrence in et at the track.
I've heard of a few flexplates cracking but myself personally have never had an issue with the flexplate. Also, get a good aftermarket trans cooler.
LS-ONE_DAY
04-12-2012, 11:44 AM
I have been going back and forth between Yank and Circle D. Chris at Circle D is a great guy to deal with, so are the people at Yank.
FiredUpZ28
04-12-2012, 11:47 AM
Correct me if I'm wrong but for a nitrous car wouldn't you want a tight converter and short (numerically higher) rear gear? Maybe thats if your spraying hard off the line... I've always wondered about this since I get so many various opinions on what works well. One of our ex-technicians used to do nothing but race F bodys and said loose converters make a stock car faster but in the end once your making good power all they do is create heat and shred the trans.
NC98Z
04-12-2012, 03:27 PM
Good thing you got rid of that technician. A good stall converter will get you to your desired powerband and keep you there with modified shift extentions. It is true that a stall convertor for a NOS car will be tighter than a stall made for a NA car. But they are completely different performance wise.
mjs1012
04-12-2012, 04:11 PM
yank ss3600. Im putting mine in along with an flt trans. this converter works great with nitrous im told.
D14HUGGER.ORANGE
04-12-2012, 06:23 PM
Yank SS3600!
SAPO-99LS1
04-12-2012, 10:27 PM
Thanks For all your answers .. I really do appreciate it... So I think I'm going for a Yank SS 3600.. What Flex plate Should I get? What brand... Umm And so far the cheapest I have found yank for is $800 S&H... Is there any better price I can get from any store online? Thanks again guys!!!
SAPO-99LS1
04-13-2012, 12:23 PM
Heard a stall converter sucks for roll racing is this true??
astro11271984
04-13-2012, 12:40 PM
i have a 3200 circle d and im satisfied with it
sepsis
04-13-2012, 01:07 PM
No, it's not true.
Not from what I've seen and read. The car gets up into the power band much quicker.
I'm not an expert on stalls, but I do know they help all around for racing.
sabersaw30
04-13-2012, 04:31 PM
Fti 3600 gets my vote.
