I'm re-assembling my LS7 and do not recall how the rods go they fit pretty much any way but i know there is only one right way. Any help? or pics?
Thanks
Buddy
alcohol altered
04-12-2012, 10:16 PM
The numbers on the side of the rod at the bearing halves will face to the outside. So if your holding the piston in your hand like you are going to stick it in the block you want the numbers facing you.
