Carbureted LSX forum - New best for my cam only carbed lq9
b_evans06
04-13-2012, 12:57 AM
Took my car to Memphis International Raceway tonight. Made 8 passes some on motor and some spray. Best motor pass was a 7.07@97 and 11.17@119 with a 1.57 60ft. Sprayed it 150 and it went 6.58@107 and 10.37@120 with a 1.56 60ft hitting the rev limiter on the big end. Engine specs as follows:
2004 lq9
stock bottom end with arp rod bolts
tsp tsunami cam
gmpp single plane
750 mighty demon
th350 with 4k stall
9" rear with 4.30
275/60/15 m/t drag radials
Timeslips below. I was car 49. Videos on the bottom.
http://i106.photobucket.com/albums/m258/b_evans06/523868_10150812270000466_502295465_11815930_131698 751_n.jpg
http://i106.photobucket.com/albums/m258/b_evans06/546603_10150812216225466_502295465_11815736_191995 6561_n.jpg
http://www.youtube.com/watch?v=OmXgL60ErIE
http://www.youtube.com/watch?v=nHRPS11UmKI
smokin91rs
04-13-2012, 05:35 AM
are your runnning out of gear on the big end on spray 119mph na and 120mph on a 150shot 1/8 mile looks good but somthings off on the big end
b_evans06
04-13-2012, 07:26 AM
Yea hits the rev limiter before the 1/4 mark. The car is geared for 1/8th mile cause this track was closed when I put in the rear end.
ZONES89RS
04-13-2012, 08:34 AM
Yea, was goin to comment on the mph issue. Damn good, but the top end is just there for improvement with more gear.
b_evans06
04-13-2012, 11:08 AM
Yea I put the 4.30s in because I have only raced 1/8 mile until this time. The local tracks are all 1/8 and this track just opened up last fall and is a 1/4. I will eventually swap gears and pick up a second center section to have for both.
1970camaroRS
04-13-2012, 11:32 AM
Where is your limiter set? I guess that stall is still fairly loose at the top end, but 4.30 gears with a 28" tire should be somewhere near 6,200 RPM. That's kind of low for your combo. Raise it to 7,000 or so and you're in business.
b_evans06
04-13-2012, 11:46 AM
Limiter is set at 7000 already. Think it is slip from the stall added from the nitrous. It does have a balloon plate in it. It is a ptc pro race converter.
streetknight2
04-13-2012, 12:12 PM
What does your car weigh?
1970camaroRS
04-13-2012, 12:42 PM
Gotcha, figured that 4,000 would have a little slip up top, but almost 1,000 rpm isn't what I was expecting.
GC99TA
04-13-2012, 02:36 PM
Great job man! I'm also curious about the vehicle weight? Also I see your 60' was the same both on and off the spray. How are you bringing it in? Delayed? Progressed? Thanks man......again....great passes for a cam only set up!
rail2k
04-13-2012, 06:11 PM
2004 lq9
tsp tsunami cam
gmpp single plane
750 mighty demon
th350 with 4k stall
9" rear with 4.30
those are really nice times congrats now im really excited about my build any vids. PLZ say yes!!!!!!!!:D
b_evans06
04-13-2012, 08:20 PM
Car weighs 3300 with me in it. I was leaving off footbrake at 2k rpms. I am using a zex window switch that sprays 100% from 4300-6600 rpms. I cannot figure out why the car won't 60 foot better. 1.55 is the best it has ever done and that was on spray. Normally on motor it goes around 1.60 range. The go pro vids are in the process of loading onto youtube. I will post them when they are done.
b_evans06
04-13-2012, 08:23 PM
I agree it seems to slip more than others. It is custom specced to my setup. I called and gave them all my info and this is the converter they sent. Talked to Kenny Ford himself at PTC. The converter has excellent street manners as I drive this car to work a few days a week and cruise town every weekend.
GC99TA
04-13-2012, 08:33 PM
Hell.....I don't know.....1.5X seems like a pretty good 60' for a cam only, 3300lb car with a 4000 stall. I've got a 3500lb race weight and a 5k converter and I only go high 1.6's.
Does your converter flash all the way to 4K when you come off the foot brake? I'm gonna guess that you've probably rolled through a significant part of (if not all of) the 60' before you hit your 4300 nitrous window. In your above slips you didn't pick up in the 60 but you gained .3 in the 330'. I would drop your window switch down to 3000 if the track will hold it. I'll bet she'll 60' then!
b_evans06
04-13-2012, 10:16 PM
I will try that next time it goes to the track. The prep is usually real good and the car hooks good with its current suspension setup. It will flash to 4k off the footbrake.
Evans is your car setup as in drag springs,shocks etc.... I have a lq4 going together and I am looking for about the same times out of it but I didnt want to full bore drag racing setup. I think those are great times for your car especially cam only.
GNCLONE
04-14-2012, 11:39 AM
That's great for cam only. No head work? stock valve springs? wow.
3,300 with you - must mean car alone 3,1??? wow again. Is the car gutted? interior? Yours and mine are the same chassis and I thought mine was light at 3250
streetknight2
04-14-2012, 08:46 PM
What lsa is the Tsunami?
b_evans06
04-14-2012, 08:58 PM
I added videos now. Cam is a 235/240 647/609 on 111lsa. I have double springs and hardened pushrods. Heads are completely stock. No porting. Car has no a/c, p/s, heat, radio, or inner fenders. I also had the passenger seat removed. The car still has all steel panels including hood as well. Suspension setup consists of stock v6 springs all around, summit brand 90/10s shocks on the front and summit brand 50/50 shocks on the rear. It has umi tubular rear control arms and a umi rear sway bar. Weighed the car at the track and it weighed 3300 with me, so 3150 with 5 gallons of gas. The car is a 100% street car that I drive 2-3 days a week year round. I put 3500 miles on this setup in the past year.
streetknight2
04-14-2012, 09:24 PM
Does it have 317 heads? Have they been milled any?
Thanks
b_evans06
04-14-2012, 09:48 PM
The heads are untouched stock casting.
GC99TA
04-14-2012, 09:58 PM
Cool vids man...it sounds great. In the nitrous video, you can hear the tone of the motor change (when the spray hits) about 10ft before you reach the 60' cone. Definately drop that window switch down and I'll bet you'll see a nice gain in your 60' and in your 1/8th ET. Only problem is you'll likely run out of RPM even sooner with those gears in the 1/4.
b_evans06
04-14-2012, 10:32 PM
Yea you can also hear it hit the rev right at the 1000ft mark. The front end comes down when I let off and then I got back on it. I think a gear change will be coming in the future.
arob987
04-14-2012, 11:46 PM
nice times put different gear and see what it does then
Prorac1
04-15-2012, 01:29 PM
Id say a differant gear, spray earlier, and up the shot a little bit and you got solid 9s on your hands. Congrats. Eric L
trav-tech
04-17-2012, 05:48 PM
i didnt read the whole thread but one thing i saw in both the videos that i would say to try not to do the 1st gear spin in the water before the burn out. it flings water up in the wheel wells and it drips back on to the tires while your staging. you motor is making enough power to pull the burn out with what ever water gets on the tires from just rolling thru the box. just my 2 cents. looks good tho.
rail2k
04-17-2012, 07:12 PM
CONGRATS ON TIME thats pretty strong for a cam only 6.0 :cheers:
