b_evans06
04-13-2012, 12:59 AM
Took my car to Memphis International Raceway tonight. Made 8 passes some on motor and some spray. Best motor pass was a 7.07@97 and 11.17@119 with a 1.57 60ft. Sprayed it 150 and it went 6.58@107 and 10.37@120 with a 1.56 60ft hitting the rev limiter on the big end. Engine specs as follows:
2004 lq9
stock bottom end with arp rod bolts
tsp tsunami cam
gmpp single plane
750 mighty demon
th350 with 4k stall
9" rear with 4.30
275/60/15 m/t drag radials
The reason for the small mph change between the nitrous vs. all motor pass is the rear gear. It hit the rev limiter just past the 1000ft mark. The car is setup for 1/8mile tracks.
Timeslips below. I was car 49.
http://i106.photobucket.com/albums/m258/b_evans06/523868_10150812270000466_502295465_11815930_131698 751_n.jpg
http://i106.photobucket.com/albums/m258/b_evans06/546603_10150812216225466_502295465_11815736_191995 6561_n.jpg
2004 lq9
tsp tsunami cam
gmpp single plane
750 mighty demon
th350 with 4k stall
9" rear with 4.30
