New LS1 Owners - Newbie Tech - Hoses for engine
View Full Version : Hoses for engine
94zGreen
04-13-2012, 01:11 AM
I'm swapping intakes, and having a very hard time remember where all the hoses go, does anyone have a diagram? Any help would be appreciated. Thanks!
bww3588
04-13-2012, 04:12 AM
Don't Have a diagram, but I can tell you.
Hose from front of passengers side valve cover goes to nipple on throttle body, hose with Pcv valve in it that runs from back outlet of drivers side valve cover and connects to passengers side rear nipple goes to the intake port on passengers side just behind the throttle body.
Evap line goes to the nipple on the drivers side of the intake just behind the throttle body.
Brake booster hose goes to large nipple on back of intake.
Vacuum line from the heater fan and such inside car goes to small nipple on back by the brake booster hose.
And if you have a 00 up, the small vacuum lines for the air system plug in there as well.
94zGreen
04-13-2012, 10:02 AM
Thank you so much!
