LS4 Performance - !!!!!!!!!!!!!LS3 Valley Covers 30 Bucks Shipped !!!!!!!!!!
Gettin Faster
04-13-2012, 08:43 AM
http://www.ebay.com/itm/2010-2011-Chevy-Camaro-SS-LS3-L99-Intake-Valley-Cover-/220982995503?pt=Motors_Car_Truck_Parts_Accessories&hash=item33739cea2f&vxp=mtr
I plan on doing the intake swap this summer. Figured I would share the find.
fubar569
04-13-2012, 08:48 AM
it does not include Orings. and the Orings are like 5 to 9 bucks a pop with 8 required.
doing the math now it doesn't seem like such a good deal when you can get a brand new right from GM cover with all orings/seals for about 100...
Low91
04-13-2012, 11:23 AM
Is there some kind of benefit to using that over the one on the LS4?
V8ImpSS
04-13-2012, 03:23 PM
Just call SLP direct and order it without eBay fees on their end, I bet they'd knock another $5 off...this is still cheaper than one from GM with outings included
The_Madcat
04-13-2012, 03:55 PM
With the LSx manifold swap for the LS4's, I believe the stock LS4 valley cover is not compatible.
DavidGXP
04-13-2012, 04:24 PM
Tray can only be used with non dod lifters and can not be used without a opsu adapter
Low91
04-13-2012, 04:34 PM
So these don't have to be cut and rewelded at an angle?
fubar569
04-13-2012, 04:47 PM
Yes they do. This is used if you eliminate the DoD with new lifters while its apart.
Non DoD lifters need a non DoD cover such as this. The stock ls4 cover is compatible if you wish to keep DoD but you will need to mod the DoD solenoid connector.
gxpsoldiergsxr
02-06-2013, 01:46 PM
wat modification can be done to the ls4 valley tray tom use it? or wat one can be bought to just put in
91parkave
02-06-2013, 02:25 PM
See sticky in the main section about davidgxp ls1/6 intake manifold swap.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
