86 K1500 5.3 SM465 swap
Hi, I am trying to finish up my 5.3 swap into my 1986 GMC. Having a few issues that I need help with. The main issue as of right now is fuel system. I have found several pumps that make the necessary psi, and flow the required gph. However as this truck is to be a daily driver I would like to run an in tank pump. I need a sender that will allow me to run a pump and still allow me to use my factory tanks. I under stand it will be on pump per tank. Now I have the understanding that a TBI sender from a 1987 pickup would work with a pump from an mpfi Tahoe/ truck say 96-98. Does this sound do able, and does anyone have knowledge of this beig done before, or going a different route?
Thanks in advance,
Brad
Thanks in advance,
Brad
