SladeX
04-13-2012, 11:10 AM
I'm going to eat some lunch first then check up here prior to pulling the starter but I wanted to see if my line of thought meshes with you guys.
Help me troubleshoot this before I go and spend $300 on a replacement starter.
Not a VATS issue:
-Security light shuts off after a few seconds
-Clicking noise made by starter
Not a battery issue:
-tried with battery booster pack
-tried 2A/10A charger for a quick boost
Not a stuck clutch issue:
-car in gear rolls back in driveway if clutch pedal pushed in
Not a neutral safety switch issue:
-if try to start with pedal normal, no click
-if push down clutch pedal, click
Thinking power to starter/or starter issue:
-will check wiring when I get under it and do some continuity tests
-starter clicks (meaning some power goes to it)
-car started fine in morning, came back home and parked in driveway, went to go and click
-noticed this happened a few days ago, but started after a few attempts, at the time didn't think much of it, but now only clicks happening
Not a VATS issue:
