toneloc60
04-13-2012, 04:13 PM
Used RTI RHS780 Digital Air Conditioning Refrigerant Handling System. This system retails for close to $5,000 new. It is used, and still very good. Everything functions properly. Has a bottle of R134A with about 8 pounds still in it. It's currently in San Antonio. Shipping weight is about 275. Buyer is responsible for shipping. I may be able to haul it for you depending on where and if the price is right. $2000 obo.
Here's the factory write up on it:
SPEED
* Patented Recovery/Recycling Process Heavy-duty compressor with true single-pass technology system for maximum throughput.
* Large Fan-Cooled Condenser
Speeds recovery, especially when temperatures are high and A/C service is in demand.
* 7 CFM Deep Vacuum Pump
Provides rapid evacuation.
* Integrated Oil Charge
Fast, easy method for oil charge.
* Digital Heated Power Charge
Programmable with high wattage thermostatically controlled heat belt. Refills most vehicles in less than 30 seconds.
ACCURACY
* Internal Weight Scale
Industrial-strength scale with shock absorber eliminates inaccuracies and frequent calibration issues.
* Rigidly Mounted Cylinder
Robust weight scale provides accurate measurement of refrigerant recovered from and charged to vehicle.
* Refrigerant Inventory
Accurate, continuous tracking of recovered, recharged, and available refrigerant. Long-term memory for cumulative refrigerant management.
AUTOMATION
* Fully Automatic Service
* Advanced Microprocessor allows you to program vacuum time, leak test, charge amount, etc... and walk away.
* Pressure Detection
Device automatically restarts compressor if residual refrigerant is detected.
* Single-Pass Auto Air Purge
Quickly and automatically eliminates noncondensable gases.
INTUITION
* Digital Readout
Easy to understand. Plain language information and technician prompts. No tutorial needed. So easy it makes any technician an A/C expert.
* Solenoid-Controlled
Gauge Manifold No panel valves to open and close. Solenoids automatically open high and/or low side, eliminating potential mistakes.
RELIABILITY
* Pressure Protection
Suction pressure regulator protects compressor and other critical components.
* Durable Components
Powder-coated steel cabinet and the highest quality compressor, solenoids, circuit board, switches, wiring, filters, weight scale...
* Field Proven Reliability
RTI A/C machines are the choice of the world's largest service chains and tens of thousands of satisfied customers around the world.
SPEED
ACCURACY
AUTOMATION
INTUITION
* Digital Readout
RELIABILITY
