lowered car with wide tires....
it rides really crappy sometimes... i know that it will with the car lowered and also I have 275/40/17's all the way around and it will jerk alot to the right or left if the road is uneven....
can i get it to handle any better? or am i stuck with that
Originally Posted by Kens_02SS
can't help crappy roads i know how you feel though, i've got 285's in the rear of mine
IMHO its just part of driving a performance car. The same characteristics that make it handle good in the corners will also make it dance around and jerk on crappy highways. That's why a caddy floats over the crappy highway and is horid in the corners (generalizing caddy's...i know not all of them are this way....don't want to **** any caddy owners off.....ha)
Shorty Director
My car when it was running rides great as well. You cant tell the difference from stock to now during normal cruising, but it tightens up when you hit the twisties.. I have Eibach Pro Kit mated to revalved bilsteins. I am running 275's in the front and 315's in the rear. Hell on road trips the car is smooth.
Restricted User
Alignment! Tell them whats going on, and they can compensate for it some. I forget, its not toe-in or out, but I believe its caster adjustment, might be camber, but its one them. Caster the relationship of the wheels fore & aft centerline as seen from above, too far back acts like a grocery cart wheel floppign around. So, maybe camber, the relationship of the two front tires to eachother = Parellel to eachother as seen from the front, if the bottom is out, looks like the rear of a Honda with load in trunk. Or the opposite, where the tops of the tires are farther out, making it look like a tractor. Lowering will effect this. Just have it check and when they read the printout, explain what its doing, and they might be able to adjust it some.
Charlie
Charlie
Alignment will solve most of the problem. Have the toe set to 0, the camber set to -.1 degrees, and the caster to 4.3 degrees.
That is the performance end of the stock range....so you will get good tire wear with slightly better handling. That should calm the tramlining down a lot.
Check this link for more info on tramlining and things you can do to minimize it:
http://www.tirerack.com/tires/tirete...tramlining.jsp
