Drag Racing Tech - What alternater bracket with motor plate?
ctjohns
04-13-2012, 09:41 PM
Anyone using an alternater along with a motor plate? Currently, my gm style alt. is on the lower left, but will hit the motor plate...needs to go up top I assume, but need a new bracket. Thanks for any advice. Chuck
Should mention, use an electric pump, alt. is the only item running off the crank.
5.3LJimmy
04-14-2012, 12:57 AM
You can use the bmr bracket if you mill it down whatever thickness the motor plate is. Then trim the plate to clear the alternator.
ctjohns
04-14-2012, 05:55 PM
I currently have a bracket similar to theirs and that is what I figured I would have to do...looks like it may take a big chunk from the lower part of the motor plate though. Thanks, Chuck
Firehawk441
04-15-2012, 07:00 AM
BMR bracket milled .250"
http://i557.photobucket.com/albums/ss17/firehawk441/IM000393.jpg
1994z
04-15-2012, 07:21 AM
i just milled my stock bracket down 1/4" and notched the plate to fit.
ctjohns
04-15-2012, 10:34 AM
Fire hawk, that is what I'm looking for! Is that a KTS plate by any chance? Also, I run the ATI damper with the built in pulley...by any chance is that your setup? Thanks, Chuck
Firehawk441
04-15-2012, 10:50 AM
Yes. KTS plate. ATI balancer with a HTD drive and stock serpentine
http://i557.photobucket.com/albums/ss17/firehawk441/IM000432.jpg
ctjohns
04-15-2012, 07:57 PM
Thanks for the info, appreciate it, Chuck
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
