FS: SBC Holley Stealthram with extras
Category: Engine - Intake/Fuel
Price: $750
Part Fits: 67-92 Chevrolet Camaro
Location (State): KS
Item Condition: Used
Engine: Small Block
LS Engine?: Non-LS Part
Package includes intake, plenum, billet 2x58mm throttle body, fuel rails, cross-over, adjustable fuel pressure regulator, MAP, coolant temp, and air temp sensors. TPS, IAC are included on the throttle body. Does not include injectors.
This package also comes with working GM small cap HEI distributor, set of plug wires, distributor hold-down, Lokar throttle cable kit, spare non-adjustable fuel pressure regulator, spare adjustable fuel pressure regulator, TPI/LT1 nitrous plate, spare short fuel rail (in case you want to run normal bypass regulator), spare front cross-over, hand full of rail fittings, stack of new plenum gaskets, 2 new throttle body gaskets, 2 sets of throttle body bolts, water neck and 160deg thermostat, and new set of 1205 Fel-Pro gaskets. Everything pictured..
The base has been ported (gasket matched to 1205 and radiused entries at the plenum). I welded solenoid bracket mounts to the base (can see in picture between runners) and had also added a raised fuel rail mount to accomodate NOSzles, however they have been removed (cannot see the mod, hidden behind rails). Intake is used and could use a little cleaning but is in perfect working order.
$750 shipped with everything.
Call/text (7won2)435-9ate63 (7am-10pm please)
PM for paypal address
