Front Dams
Front Dams
Removing the plastic "grill" piece, I have the styrophone behind the two holes. Have people cut this stuff out and if so does it go straight through to the radiator? Wanna know before I cut.
Copy & Paste Moderator
A lot of people just paint the foam flat black so its less noticable instead of actually cutting it out. Some also put some wire mesh in the openings
Here is a pic of Ratio411's car:
http://images.cardomain.com/member_i...71_29_full.jpg
Here is the thread where I found it posted:
https://ls1tech.com/forums/showthrea...ight=grill+mod
--VIP1
--VIP1
It does look really sharp with the mesh there. I was hopeing to increase the air flow to the lid via running a set-up that would pull the air in through the dams. Something like this corvette on the right @ http://www.vararam.com/
What do you think?
What do you think?
