General Maintenance & Repairs - Steering wheel vibration upon acceleration
98TransAmAngryBird
04-14-2012, 01:14 AM
Hey guys.. I just recently had my tranny pulled, rebuilt and then reinstalled. I got the car back today and noticed that my steering wheel was vibrating while accelerating from a complete stop. The vibrating was enough to shake my hands while driving... You guys think it has anything to do with the transmission?? Before the rebuild I never had this problem.
Tommyv8
04-14-2012, 08:08 AM
A4 or M6?
98TransAmAngryBird
04-14-2012, 09:10 PM
A4.. Ya its just a light vibration while first accelerating. Its a nuisance man..
2000whitevert
04-16-2012, 11:00 AM
I have the same problem with my z if anyone has had this problem and know what it is id really appreciate a response! Thanks, Mike
djfury05
04-16-2012, 11:56 AM
Is there anything else shaking in the car? I'd do the obvious visual checks first. Bushings, ensure all nuts and bolts are tight, inspect the steering column from the firewall to the rack etc. Maybe the tires need rotating now from alignment issues.
2000whitevert
04-16-2012, 02:52 PM
My vibrations i think are coming from the tranny. When im sottin in park and bring the r's up it vibrates but the car shifts and drives fine just has vibrations? ???
LS100CAMSS
04-21-2012, 10:26 AM
Driveshaft could be out of balance.
2000whitevert
04-21-2012, 02:18 PM
Any1 encountered this problem before? It has to be in my tranny/convertor in order for it to have these vibrations while in park
Team Hopt
04-26-2012, 03:38 PM
Bump. Same issue after my trans was put back in.
chrysler kid
04-27-2012, 04:17 AM
Check your motor mounts. If they flexed them hard after pulling the trans which is most likely the case the motor could be vibrating enough to upset the steering rack. At least that's my theory
blade2222
04-27-2012, 06:47 AM
Did they put in a new trans mount? If they did could be your old one was worn out and the new one is transmitting vibration to the steering column.
