New LS1 Owners - Newbie Tech - New LS1 Owner.. Please help!
Brendan11
04-14-2012, 01:29 AM
Ok here is the deal, I recently bought a 1999 Camaro Z28. The car seems to run good I guess but it has a few problems I need advice on. The security light is on, airbag light is on, she's light came on then burned out and needs replaced, the codes popped for o2 sensors.
I am hoping to clear some of not all the lights and do a tune up to the car because it has 137xxx miles and I don't believe it has ever had a tune up.
This is my first ls1 so any and all advice is welcomed, and if there is anything else I should do please let me know...
Also, I am trying to keep it somewhat low on price as I am only a senior in high school and don't have a ton of money...
Thanks in advance!
Brenda
Tommyv8
04-14-2012, 07:59 AM
My security light goes off and on too because of a malfunction with the notoriously problematic VATS (vehicle anti theft system). It reads the little metal resistor in the key when you start the car. Sometimes it causes my car to not start with the key, forcing me to use my remote start (good thing I have that). And sometimes it starts with the key just fine. You can do a search on here to find a relatively cheap and easy way to fix the VATS problem.
I also happen to have the SES light on because of an O2 sensor. The car still runs fine, although my gas mileage may be suffering a bit. Also a relatively cheap and easy fix that I'll get around to eventually, not a big priority.
TransamGCS
04-14-2012, 08:00 AM
for the airbag light might be the SIRs coil its a spring that turns when you turn the steering wheel and keeps the connection for the airbag, do you have radio controls on your steering wheel if you do and those arnt working either, than the Sirs coil is probably broken which would disable your air bags and cause the light to come on, as for pulling O2 codes what codes did you get? i assume you mean the ses light bulb burnt out if thats the case you have to pull out the speedometer cluster and change the bulb out from behind, the security light issue im not sure never had that issue. YES i would defiantly do a tune up and have the spark plugs replaced if you do them your self there are several wright ups on how to do it just search for it , changing the spark plugs isnt that bad the only one that is a pain, is the one on the last cylinder on the passenger side if you take it to somebody take it to a good mechanic that has done ls1 before some places will charge you a arm and leg to replace spark plugs because of the one thats on the last cylinder on passenger side
Tommyv8
04-14-2012, 08:05 AM
People might make fun of me but I just had a mechanic change my plugs while he was changing my front shocks (another big PITA with these cars). Screw it, it's not my fault that GM decided to shove half of the engine under the cowl.
Brendan11
04-14-2012, 12:22 PM
Any adivce on what plugs and wires? I want something good but not extremely expensive. Also is there anything else I should do to it?
I will have too look at my codes again, I don't have my receipt from autozone handy at the moment, when I get them I will post it.
Brendan11
04-14-2012, 12:28 PM
I do not have the steering wheel controls, so how would I know if it is the VATS or the SIRS coil?
BigBirdLS1
04-14-2012, 01:07 PM
As far as plugs and wires you can't go wrong with a set of MSD wires and NGK TR55 spark plugs. I really can't help you with the Vats and airbag light sorry OP.
TransamGCS
04-14-2012, 01:10 PM
Spark Plugs youll want NGK tr55 and i personally like MSD wires go to nastyperformance.com they have the best price on the plugs and wires they come as a package. The VATs has to do with the chip on the ignition key not the SIRS coil, the sirs coil is what connects to the air bag i dont know how to tell if its the sirs coil is causing the air bag light what i do know if the coil spring is broken that will cause the airbag light to come on cause their will no longer be a electrical connection to the air bag and the coil is in a housing so its not like you can remove the air bag to see if the coil is broken when you replace the sirs coil you replace the whole housing i think the coil costs a little less than 200 bucks so depending on your mechanical skills you might want to have that installed professionally
Brendan11
04-14-2012, 01:30 PM
I'll check those out. Thanks!
As for the whole airbag thing I read somewhere that you don't really have to worry about it, it won't screw with emissions or anything and I heard people just put take over the bulb or take it out so it doesn't show. Since I am taking the gauges out any way I might just do that, any advice on if that is a good idea or not?
TransamGCS
04-14-2012, 02:00 PM
well thats entirely up to you i mean its a safety thing so... just know that if the air bag light is on that means the air bag is inoperable so if you get into a accident the air bag will not deploy.
Brendan11
04-14-2012, 02:41 PM
I may just deal with the light and whenever I get the money have someone check it out and fix it. Any ideas on price?
Sorry for all the questions, just new to this and looking for advice..
DETROIT_AREA_00_SS
04-14-2012, 03:51 PM
If you end up needing a new aigbar sensor (under center console) I have mine sitting on a shelf in the garage. $25 shipped.
Brendan11
04-14-2012, 04:14 PM
I may just do that and see if it fixes it. But I read somewhere those things have to be mated to the car and airbags?
DETROIT_AREA_00_SS
04-14-2012, 04:27 PM
No that I am aware of, I see them for sale quite often.
Brendan11
04-14-2012, 04:48 PM
Ok, I may take you up on that then..
IceHammer
04-18-2012, 07:56 AM
Your security light coming on and not letting you start the car may be related to bad solder joints in the Body Control Module (BCM). I had that issue and fixed it by re-soldering the circuitboard of the BCM. Took maybe an hour, 55 minutes of which was wrestling the stupid thing out from under the dash.
http://ls1tech.com/forums/general-lsx-automobile-discussion/883334-ls1-body-control-module-problems-fix.html
ryeguy2006a
04-18-2012, 10:59 AM
Could be the Key. Don't those have the transponders in them. Maybe try a new key.
