General Maintenance & Repairs - Plug wire question
bigbomber5
04-14-2012, 01:09 PM
Im changing spark plugs and wires in my 02 TA. My question is, what is this silver metal jacket piece that is coming off with the wire on the plug side. I'm guessing it is supposed to come off and I insert my new wire inside this then put it back on the plug?
Blu99T/A
04-14-2012, 01:17 PM
It is a heat shield.
Yes re-install them on your new plug wires.
bigbomber5
04-14-2012, 01:26 PM
Thank you. Just making sure :)
sjsingle1
04-14-2012, 06:00 PM
i did not re-use the metal shields on my MSD or Granatelli wires..........FWIW
bigbomber5
04-14-2012, 06:36 PM
Hmm that's interesting. Im using MSD wires as well. It would definitely make popping on the wire a lot easier
BTW, changing plugs and wires makes me hate my car!! I'm on the back 2 on the passenger and called it quits for the day
Blu99T/A
04-14-2012, 07:27 PM
I am sorry, I was assuming you were using stock replacement wires. If you are using MSD or any other quality wire, you don't need to use the heat shields.
bigbomber5
04-14-2012, 08:08 PM
Cool thanks man.
I read lots of threads before changing the plugs/wires and no where did it mention the metal heat shields come off with your plug. I thought I was yanking shit out of the motor!! :) lol
I'm going to take them off tomorrow. Should be easy since the driver side is cake
01 CamaroSS SLP
04-14-2012, 08:33 PM
Don't use them with MSD
bigbomber5
04-14-2012, 09:15 PM
Will do
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
