Pulling heads with studs?
Old 04-14-2012, 02:34 PM
mypoorLS1's Avatar
Default Pulling heads with studs?
Do the studs need to come out, or will the heads fit over them. Car is a 98 Fbody
Old 04-14-2012, 02:56 PM
bww3588's Avatar
tight squeeze but it can be done. Just as easy to unscrew the studs just like bolts IMO.
Old 04-14-2012, 02:58 PM
Darkman's Avatar
https://ls1tech.com/forums/generatio...ads-studs.html
https://ls1tech.com/forums/generatio...heads-car.html
Old 04-14-2012, 03:26 PM
tillery's Avatar
Ive done it a few times on my 2000 f body. You have enough room to do it. Without pulling the studs out.
Old 04-14-2012, 03:38 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
On the passenger side, you have to leave them in, specifically the bottom ones in the back since there isn't enough room to remove them with the head on the block.
Old 04-14-2012, 04:05 PM
mypoorLS1's Avatar
Thanks guys. Just wanted to know what I was in for. I'm about to start the job. A few guys asked about that. I thought there was room. I'll take my thread chaser with me just in case
Old 04-14-2012, 04:34 PM
01ssreda4's Avatar
Taken mine off several times. None have to come out of the block. Anyone who tells you otherwise doesn't know what the hell they are doing
Old 04-15-2012, 03:17 PM
Schantin's Avatar
As stated, the heads can come off with the studs still in the block. Done it before .... no issues
