Paint & Body Work - Which sanding paper?
View Full Version : Which sanding paper?
2QuikTA
04-14-2012, 06:19 PM
If I just want to take off 1 coat of rattle clear, what grit should be good?
critical.in.ga
04-14-2012, 07:56 PM
What is under the rattle clear?
98camarols1
04-14-2012, 09:21 PM
what are you trying to accomplish?
2QuikTA
04-14-2012, 10:10 PM
Well, I'm trying to paint my lower airbox. I sanded it down for the most part but didn't get all of the texture in some spots. Sprayed a gloss black and came out fine, you couldn't see/feel the spots that still had slight texture. When I went to spray some clearcoat, it cracked in the spots that the texture was still there. If the top coat looked good though, I don't understand why/how the clear would go on bad if the top coat didn't.
Jr.Samples
04-14-2012, 10:34 PM
40 grit on a d/a J/K I would try 1500 wet and see if that would work.
98camarols1
04-14-2012, 11:05 PM
you can sand it with 800-1000 and reclear it
