Forced Induction - Truck manifoldkit with stock k member?
wg871
04-14-2012, 06:39 PM
Has anyone out there fabbed a truck manifold kit while using the stock k member? Is this possible or is a tubular k member absolutely necessary? Thanks
ep142
04-14-2012, 07:55 PM
it can be done, just have make some clearance on the passenger side.
http://ls1tech.com/forums/forced-induction/1425614-98-02-f-body-single-hot-side-turbo-kits-starting-799-a.html?highlight=modular
a-low
04-14-2012, 08:18 PM
Huron kit uses stock k member
http://ls1tech.com/forums/forced-induction/1510833-huron-speed-single-truck-manifold-kit.html
Ping King
04-14-2012, 08:45 PM
What are your goals for power? Your downpipe size is limited with a stock k member. I was able to stuff a 4 inch DP over the motor mount, but i couldn't use a pass truck manifold.
BOBS99SS
04-14-2012, 09:03 PM
i plan to do mine with a stock k member, my plan is to cut a hole in my car for a dp lol
95maroz28
04-14-2012, 09:17 PM
i did but have solid mounts, the studs pretty close on passenger side just had to grind enough to get a wrench on it
Tally TransAm
04-14-2012, 09:55 PM
still running a stock k member with no plans on changing
fastsspr
04-14-2012, 10:57 PM
What you used to replease the truck manifold ?
boss79z
04-15-2012, 12:20 AM
Stock k member here. No grinding on k-member her. We popped the stud off the manifold and replaced it with a shorter bolt.
Sweet_SS
04-15-2012, 12:36 AM
Stock K member here as well
BottleFedZ346
04-15-2012, 02:07 AM
Stock k-member here as well, no grinding or notching done....
I do however have v-bands on the manifolds rather then the stock flanges....
Adam86
04-15-2012, 09:51 AM
Stocker here. Had to do a little notching though.
JaYZeig
04-15-2012, 10:24 AM
stock k member here..with 3.5 in downpipe...of course with spohn solids, they free up so much room!
Ryans99ls1
04-15-2012, 07:16 PM
stock notched kmember here. welding vbands to the manifolds is the best option if you dont want to notch anything
Ping King
I built a forward swept turbo manifold.
I also have a build using a stock pass and a flipped truck on the drivers side.
Its tight, but i fit a 3" DP as well as retained AC.
