Conversions & Hybrids - My Spectre efi tank
flywheel
04-14-2012, 07:59 PM
Took my tank out last year and put in one of the Buick GN tanks w/Walbro pump. It solved the problem of dieing while going around corners low on fuel, but wasn't the easiest to fill and hung a little low.....Got a wild hair and decided to try the Spectre POS tank again, this time I put the walbro pump in, drilled four more 3/8" holes in the sump,and then welded a divider plate running front to rear between the sump and the filler neck. It seems to work now, NO fuel starvation, with as much as 3-4 gals of gas in it and doing circles in the school parking lot as fast as I can......YEEEEHAAAAAAA!!!!:nod:
Rick
1slowta
04-14-2012, 08:02 PM
Did you by chance take any pics?
Che70velle
04-14-2012, 08:22 PM
Yeah, and pics of the tank also...lol
SUPERBOOST
04-14-2012, 08:42 PM
Which walbro pump did you use?
weircc
04-14-2012, 09:33 PM
is this an older or newer tank? i read the have redone them
flywheel
04-14-2012, 09:55 PM
It is an older tank, and no I didn't take any pics, I wished I had. Before I even put the tank in (the first tym)I was concerned about having that problem so I had a sheet metal buddy weld in a divider IN the sump tub. But it still didn't help. So, Im not sure if its the new pump or the divider helping keep the fuel closer to the sump. Just glad it all works now.....
Rick.
flywheel
04-14-2012, 10:05 PM
Don't remember, got it from Summit. Walbro 255, think it fit alot of V8 chevy's.
futureuser
04-14-2012, 10:49 PM
There really isn't much difference between the old tank and new one. Just an extra baffle splitting the bowl or "sump." That being said I haven't had any issues with my newer one. I also used a walbro and described it's installation in the yeah or neah thread.
kirk69nova
04-15-2012, 12:03 AM
I am interested, what is the yeah or neah thread?
futureuser
04-15-2012, 12:14 AM
http://ls1tech.com/forums/conversions-hybrids/1382944-spectra-efi-gas-tank-yay-nay-13.html
downset71
04-15-2012, 01:19 PM
Dumb question. Ive had issues with my homemade sumped 71 a body tank. What are everybody thoughts on a double tiered sump? Im thinking about adding a lower sump under my existing sump. Drill another 4 or 6 two inch holes into my sump and just welding up another level underneath. Fuel would drop down into 2 isolated chambers. Dont think it would ever be able to slosh out!
flywheel
04-15-2012, 07:37 PM
Futureuser, you said you had trouble fitting your Walbro pump into the spectre tank! I took the one out of the GN tank and put it right into the spectre tanks sending unit setup. I didn't have any touble at all....hmmmmmm!
Again, the troubles were only when going around corners with 1/3 of tank or less!
Rick
flywheel
04-15-2012, 07:55 PM
I think The one I used was GCA758-2 from Summit....
futureuser
04-15-2012, 08:00 PM
Rick
I don't see you posting details of your pump swap. I showed pictures, part numbers and the problems I ran into. There are more than one Walbro 255. Can you share with the rest of us which part # pump and sock you used so the the rest won't run into the minor issues I did?
No doubt there are far better tanks than the spectre, but my set up does not starve, below 1/3 tank, and I have yet to see a car at the track with a rick's tank.
flywheel
04-15-2012, 08:36 PM
Hey, I didn't mean anything mean about your post, After re looking at your picks I can see yours was alot different than the one I used, I just wondered why yours seemed like it was so much more work than mine, I didn't look at the pics that close when I skimed over the post. Sorry, but I don't take alot of pics and keep alot of details on the stuff i do.
Rick
flywheel
05-07-2012, 07:31 PM
Here's some shots of the changes I made inside of my Spectra tank... I had to pull the tank again cause the fuel sending unit went out...The first one is the baffle I put in running front to rear, the second one is inside the sump tank, 3rd is the top cuts in the tank, 4th,5th are shots of the walbro pump.
Hopes this helps someone....
Rick
futureuser
05-08-2012, 08:16 PM
Sorry to hear you're having so many problems with yours. Thanks for posting up the pics.
