Just an FYI on Anti-Seize on Sparkplugs
I saw that NGK Tech Bulletin when I changed my plugs last fall. I decided to use a small amount of aluminum head spark plug anti-seize anyway, and torque to the service manual spec of 11 ft-lbs. When they torqued up they seemed just fine - ie, they snugged up quick and 11 ft-lbs gave them just a little more rotation.
The Scammer Hammer
Damn. Guess I better change mine out. I used anti-seize, pretty sure I far surpassed 11ftlbs too. By A lot. I use German torque specs for damn near everything.
I guess the TR55's have the special coating....
Also, I see the compressed gasket in the bulliten. We don't have that, as we have tapered plugs. I wonder how that affects things, if at all.
Tapered Seat with Aluminum Heads
7 to 14 ft-lbs (note GM spec of 11 is mid-range)
or
Hand tight (snug) + 1/16 to 1/8 turn
In this case, "hand tight (snug)" means when the taper on the plug just seats in the head by finger tightening.
11 ftbs is 1/8 of a turn or less from when the plugs taper touches... they need to be barely snug, they will stay in.
I still would use a small amount of antiseize.
anitiseize
we change plugs every pass when tuning in our big motors(780",706"), probably 70 sets or more last year. always with antiseize and never once had a problem. you can feel the gasket compress if you take your time.......plugs from the bulletin look like someone didn't know wtf they where doing.......
Ive never used anti seize where anything needs to be torqued. Like paul bell said. A light coat of clean oil is fine. Anti seize cakes up when the oils fall out of it. And of course improper torque.
I'm looking at the package of some Permatex (Loctite Corp) anti-seize and it says to torque to manufacture's specs ... so apparently they are not worried about the torque spec being very far off when using the anti-seize.
I hold the ratchet with my thumb around the head and my hand has about 3-4 inches of the ratchet in it is all and tighten pretty firmly. They make spark plug ratchets, little stubby dudes only about 5 inches long total.
